cam on stock block?
Old Oct 11, 2007 | 11:37 PM
t0ekn3e's Avatar
Default cam on stock block?
I'm plan on purchasing a b16 head and send it out to portflow and get their standard honda headwork with valvetrain. I am stuck at which cams I should use for a stock jdm itr block with achieving the most power. I was thinking s2s2 or maybe jun3, so what would you guys recommend? TIA
Old Oct 11, 2007 | 11:57 PM
doood's Avatar
been there done that
Default Re: cam on stock block? (t0ekn3e)
s2s2 and jun3 are pretty much identical
Old Oct 12, 2007 | 10:34 AM
t0ekn3e's Avatar
any suggestions then?
Old Oct 12, 2007 | 12:27 PM
b19coupe's Avatar
Toda B
Old Oct 12, 2007 | 12:32 PM
707CIVIC's Avatar
i got jun3 in a b18c not alot of toque but very good high end.
Old Oct 12, 2007 | 01:24 PM
soaringchimp's Avatar
What kind of bolt ons do you have in place, and what stock block is this B16 head going on?
Old Oct 12, 2007 | 01:36 PM
cartune network's Avatar
Default Re: cam on stock block? (soaringchimp)
idunno i tend to like the buddy club 3's on stock c1 motors. the bc3 improves your midrange alot and the vtec crossover is pretty beefy.
but other than bc3's i would reccomend toda b's
Old Oct 13, 2007 | 10:54 AM
t0ekn3e's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by soaringchimp &raquo;</TD></TR><TR><TD CLASS="quote">What kind of bolt ons do you have in place, and what stock block is this B16 head going on?</TD></TR></TABLE>
jdm itr short block, hytech knock-off header, extrude hone itr intake manifold
Modified by t0ekn3e at 12:15 PM 10/13/2007
Old Oct 13, 2007 | 11:19 AM
Natural Aspirations's Avatar
No love for the Pro1's? Wow I'm shocked
Old Oct 13, 2007 | 11:22 AM
Default Re: cam on stock block? (cartune network)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cartune network &raquo;</TD></TR><TR><TD CLASS="quote">idunno i tend to like the buddy club 3's on stock c1 motors. the bc3 improves your midrange alot and the vtec crossover is pretty beefy.
I do not know what your doing to these c1's to get a beefy crossover with BC3's but I have installed 2 sets in the past 3 months and the crossover is VERY mild. Maybe you should adjust your engage point, it should be very seamless with this cam.
Old Oct 13, 2007 | 06:04 PM
t0ekn3e's Avatar
up
Old Oct 13, 2007 | 06:55 PM
Rickdrizzle's Avatar
skunk2 stage2.
Old Oct 13, 2007 | 11:49 PM
t0ekn3e's Avatar
whats difference between s2s2 and s2 pro1. i looked at specs and saw intake lift is higher and duration is shorter on the pro1. but i have no idea what it means
Old Oct 14, 2007 | 06:00 AM
00Red_SiR's Avatar
All Motor Mentor
Default Re: (t0ekn3e)
Pro 1 cams are larger than the s2s2 original tuner cams and will make more power. They also have larger primary lobes than the stock like s2s2's and will make a lot more power down low. They can be a little harder to tune than the originall s2s2's but much more rewarding when done right. You might want to consider the Rocket Motorsports M22x cams for that engine. I have them in my 1.8 and I really love them and you don't have to spend much time tuning them. My car runs like stock with them.
Old Oct 19, 2007 | 02:15 AM
t0ekn3e's Avatar
would pro 1 be too much?
Old Oct 19, 2007 | 08:32 PM
00Red_SiR's Avatar
All Motor Mentor
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by t0ekn3e &raquo;</TD></TR><TR><TD CLASS="quote">would pro 1 be too much?</TD></TR></TABLE>
Definitely not, there's plenty of examples on here to support that.
Old Oct 20, 2007 | 06:05 PM
UncleD's Avatar
Default Re: (00Red_SiR)
Pro1 - S2S2/Jun3/Wicked stage 2/Blox B/BC4/"Bumpstix" - M22x. Pick.
Mike K
120
Apr 15, 2017 01:58 AM
krucial7integra
Apr 13, 2008 12:25 PM
cvccr
Jun 13, 2007 03:45 PM
chunky
10
Oct 2, 2005 03:46 PM
theslugbug
11
Aug 5, 2005 05:37 PM
