Power option swap
Old Oct 11, 2007 | 09:30 PM
basil's Avatar
Default Power option swap
Ok, I have a very unique situation and have tried to find what I am looking for by searching, but have had no luck.
recently I bought the floor harness, dash harness, both door harnesses and the power options to go with them from a 99SI. I tried to install that into my 98DX coupe and they would not fit... the plugs were not compatible. So I kept the door, and bought a floor harness and dash harness from a 97EX coupe and installed them today.
here is my issue; the power locks do not work. So can anyone suggest something that I might have missed? I will try and test the locks but I dont really have time to do so until monday... Also, I dont have a power window relay yet, so I know those wont work until I get one.
Old Oct 11, 2007 | 09:39 PM
marshun's Avatar
Default Re: Power option swap (basil)
you got the relay and fuse in there for the locks?
i've done a power window and lock swap on mine and it was just plug and play. the dash should be the same also. i still want that for my car
Old Oct 12, 2007 | 06:53 PM
basil's Avatar
Default Re: Power option swap (marshun)
I did not know that there was a relay for the locks... and yes, the fuses are in there. do you have a part number or a reference to a power lock relay? thanks
tortiosboy
Oct 8, 2018 08:55 AM
HondaBondMan
Mar 19, 2006 02:01 PM
HondaBondMan
Mar 5, 2006 07:40 PM
