wheel hub assembly
i rotatated my tires and striped to wheel studs ,got some new ones took of my caliper than the rotor but the wheel hub assembly wit the litlle plate where the wheel studs are on just wont budge anyone knows how to take that thing of il be very thankful
yea i just did it i duno if it was the right way or not but i sprayed it real good with wd 40 waited a whiile sprayed it agen and i hit off with a hammer itcame off pretty easily
just did it the other day, its a slide hammer that attaches to the wheel studs, try to rent one from an autoparts store, or do what this guy did, also remove the big nut in the middle (32MM) and hit it from behind with a hammer.
hit that **** with a hammer. and when u put it back on just put a thick washer on the stud and get a 19 socket and tight it up it should fall in to place. i do it all the time. its ez.
Is it the front or rears...? For the back you need to take off the metal shield (center caps hides it) and the big nut off. From there a little tap should bring the hub out. For the front you will need to get it pressed.
