popping noise and lag
Old Oct 11, 2007 | 06:47 PM
shadohconspiracy's Avatar
Default popping noise and lag
ok so this is whats going on. when my car idles at a stop light or w/e sometimes the exhaust will make popping noise. and i notice that sometimes when i am just driving nomally my car will lag as if the spark plug wires were not all the way on (i made sure they were all the way on). help?
Old Oct 11, 2007 | 06:49 PM
forcefedferio's Avatar
Default Re: popping noise and lag (shadohconspiracy)
man your just having all kinds of problems.....check plugs and wires first could be due for a tune-up.
for better luck
Old Oct 11, 2007 | 06:52 PM
yes sir
Old Oct 11, 2007 | 07:12 PM
vandersmissenc's Avatar
Default Re: (shadohconspiracy)
this is a complete shot in the dark, but this just happened to me and i had water in the spark plug cylinder. It would lag and pop and kinda sound like a harley. You just need to dry it up if thats the case. Thats a complete shot in the dark though.
Old Oct 11, 2007 | 07:44 PM
Default Re: (vandersmissenc)
did you just remove the plugs and let it air dry?
Old Oct 11, 2007 | 07:51 PM
Jbur074's Avatar
cylinder missfire possibly??? thats what mine did
Old Oct 11, 2007 | 07:52 PM
stock_honda_coupe's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vandersmissenc &raquo;</TD></TR><TR><TD CLASS="quote">this is a complete shot in the dark, but this just happened to me and i had water in the spark plug cylinder. It would lag and pop and kinda sound like a harley. You just need to dry it up if thats the case. Thats a complete shot in the dark though.</TD></TR></TABLE>
If this was your problem it would happen all the time. If yours doesn't happen ALL the time then this wouldn't be the case. If it is the case, then just dry them. I would pull a spark plug and the distributor cap and see what kind of condition they are in like forcefedferio said.
Old Oct 11, 2007 | 08:13 PM
missfiring? could it possibly be timing? but yeah it doesnt do it all the time , but it did do it more lately.
Old Oct 11, 2007 | 08:22 PM
Jbur074's Avatar
naa i doubt its timing... check the rotor in the dizzy it might be going bad and missing the spark wires.. misfiring could be occuring due to spark plugs, wires, is your firing order right?? could be something wrong with the dizzy but i doubt it if its getting spark
right?
Old Oct 11, 2007 | 08:36 PM
from what it looks like from the outside, the distributor looks brand new. tomorrow i will pull the plugs and check it. to check the inside of the dizzy do i have to pull it out and redo the timing and stuff to put it back in?
Old Oct 11, 2007 | 08:41 PM
Theres just 3 little screws. 8mm/philips I'm pretty sure and it comes right off. You don't even have to pull the spark plug wires off.
Old Oct 11, 2007 | 08:43 PM
Jbur074's Avatar
shouldnt have too... fireing order is 1342 counter clockwise... the dizzy cap could be replaced but ignition modules go out without even looking like it... i think its your rotor... could be wrong. sounds like its just not striking the wires sometimes... is it happining all the time or just everyonce in a while?
missfiring can cause a very loud poping nose, and very slow...
also check the wire crimps (i think thats what their called) mine broke off once and caused missfiring
Old Oct 11, 2007 | 08:53 PM
alright thanks guys , ill take a look tomorrow. if the stuff inside is bad how do i tell? should i just get a brand new dizzy if it is?
Old Oct 11, 2007 | 09:19 PM
Jbur074's Avatar
naa... do that as a lassttt resort.. if your near an autozone you can take the ignition module or coil and have them test it for bad grounds.. thats probly not it tho if the car starts..
when you unscrew the dizzy theres a big circle look at that and there should be like a grinderstone (like whats on lighters) that spins and strikes the sparkplug wires.. check that to see what it looks like.. also check the inside of the cap.. there should be 4 tiny metal wire looking things.. these should also look very ment.
edmfactory
Jun 19, 2012 05:55 PM
hondaboy415
10
Dec 9, 2007 03:52 PM
B20inDCinLBC
Oct 24, 2006 07:36 AM
accordisslow
Jan 5, 2006 07:09 PM
StatGSR
Jun 14, 2004 05:43 PM
