Ls vtec question?
Old Oct 11, 2007 | 06:27 PM
integramotor's Avatar
Default Ls vtec question?
Hi everyone, I am new here, but i have read and search a lot about ls vtec, so anyone can let me know if my set up is gonna be ok. I have and ls vtec, and now i gonna put a p30 piston in the ls block, and i gonna use 2 layer head gasket, so my question is: the valves will hit the piston or not? any suggestions will be appreciate!
Old Oct 12, 2007 | 09:43 AM
ITRnorway's Avatar
you should mention what crank, rods, cams and head modification you have
Old Oct 12, 2007 | 09:45 AM
Brick Top's Avatar
Default Re: Ls vtec question? (integramotor)
i highly doubt it with stock cams. but if your running aftermarket and are unsure of block and head history, clay the motor.
Old Oct 12, 2007 | 09:46 AM
Z you later's Avatar
Default Re: (ITRnorway)
+1
Old Oct 12, 2007 | 02:33 PM
thank you for your reply. well, i use the ls bottom end, ls crank, ls rod, gsr head, and gsr cam. I think later i gonna up grade the cam (skunk2 pro2) valve springs and retainer, and cam gear. So do U think the valves gonna hit the piston?
Old Oct 12, 2007 | 02:48 PM
doood's Avatar
been there done that
Default Re: (integramotor)
you're gonna have to check clearances with pro2's anyway. they're big cams.
T3T4Honda
Sep 27, 2008 01:07 PM
hondacura4life
Sep 9, 2006 12:19 PM
Turbotype
Nov 17, 2005 02:18 AM
hatchmonkey92
May 5, 2005 09:25 AM
keebler65
Feb 6, 2004 02:26 PM
