why does my fuel pump keep f.... up
Old Oct 11, 2007 | 05:01 PM
enriquev's Avatar
Default third time my fuel pump has gone out in the last 6months . . . . .help?!
k i have a 90 integra ls we replaced the fuel pump about a month and a half ago and to day it wouldnt start and im pasitive its the fuel pump again cuz it was sputtering on the way home and now it turns over but wont start why deos it keep giving out ? any ideas by the way its the third time ive had it replaced int the last 6 months thanks in advance i really dnt wont to have to replace it every month ! any suggestions
Modified by enriquev at 6:16 PM 10/11/2007
Old Oct 11, 2007 | 05:31 PM
i heart dee a nine's Avatar
Default Re: third time my fuel pump has gone out in the last 6months . . . . .help?! (enriquev)
did you replace the strainer as well and made sure the rubber ring was on right?
Are you sure it's your fuel pump? If you installed it right, and I assume it's a new fuel pump.. there could be other factors where the fuel is involved that might have cause the car to die. Replace your fuel filter and check your injectors. A friend of mines had the same problem and all he did was kept blaming it on the fuel pump.. it turns out the fuel filter was clogged. It's only $14 bucks to replace the fuel filter.
Hopes that help.
nsone
May 14, 2009 04:35 AM
Cameron60
Jan 16, 2007 06:04 PM
mini-v-si
Jun 1, 2004 03:06 PM
Z6REX-SI
10
Mar 9, 2004 07:50 AM
