My jdm b18c build
Old Oct 11, 2007 | 04:17 PM
Paul-eg's Avatar
Default My jdm b18c build
Here is my set up,
-'94 JDM B18C (GSR)
-Spoon 12.5:1 pistons
-Centerforce clutch
-Skunk 2 polished intake manifold
-T1R stainless steel 4-2-1 header
-AEM cam adjustment gears
-custom 2.5" exhaust with generic "N1" style muffler and cat
-Apex'i VAFC 2 fuel/VTEC controller
-Short ram intake
-B16b Comp tuned by A&J Racing
-Golden Eagle Cam Seal plug
-Del sol dual core radiator
-NGK Blue wires
I have a question about tuning. Its running an a b16b comp from ajr that was tuned for a car with a simiar set up. Is there a way for that the ob2 ecu to be tuned or am I just running a stock b16 ecu on the car. And is there anyway of tuning that ecu or would i have to go obd1? Also how much power you thing that build is puttin down?
thanks
Old Oct 12, 2007 | 03:19 PM
Paul-eg's Avatar
Default Re: My jdm b18c build (Paul-eg)
ttt?
Old Oct 13, 2007 | 05:30 AM
b19coupe's Avatar
Use a conversion harness and an OBD1 P28 with Crome or Hondata.
You may also use the AEM EMS.
E-Manage is also an option.
Old Oct 21, 2007 | 12:25 AM
Paul-eg's Avatar
Default Re: My jdm b18c build (b19coupe)
how much hp you thing a build like this would put down? I want to throw it on the rollers eventually but got more important things at the moment.
Old Oct 21, 2007 | 08:03 AM
b20beast978's Avatar
The only way to actually find out is to put it on a dyno. There is no way to accuratley guess hp, so finish that build and hit up a dyno!
Old Oct 21, 2007 | 10:15 AM
acydphryck's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Paul-eg &raquo;</TD></TR><TR><TD CLASS="quote">Here is my set up,
-'94 JDM B18C (GSR)
-Centerforce clutch
-Short ram intake
-NGK Blue wires
thanks</TD></TR></TABLE>
there's no way you can run a stock b16 ecu on that compression ratio...get an OBD2-OBD1 conversion harness with a P28 ecu and use hondata, crome or some sort of engine management. break it in on a dyno, if accessible, and tune it...no real accurate way of predicting whp output with your setup with just listing the parts you're using.
Old Oct 21, 2007 | 04:32 PM
Paul-eg's Avatar
Default Re: My jdm b18c build (acydphryck)
Yea its a flased ecu its not stock from ajr for a similar build
Paul-eg
Apr 22, 2008 11:55 AM
FW98DC2
Apr 13, 2008 05:54 PM
BLK99VTECR
Oct 6, 2003 10:55 AM
hybridEj6
42
Sep 7, 2003 02:27 PM
