Weird Idle Loop (I already searched)
Old Oct 11, 2007 | 03:22 PM
slacks's Avatar
Default Weird Idle Loop (I already searched)
ok. So my ecu is throwing a code 14 and 10 (ok whatever)
My car idled insanely low (300-500 rpm cold)
and only looped around 1200-1500 rpm
so when installing a new radiator, i reset the dizzy wires to the right ignition order and not the car idles higher 1200-1300 rpm cold (and still loops in idle)
which sensors should be checked in order to fix these? or is there another route?
(just to note; recent tune up and oil change)
Old Oct 11, 2007 | 07:19 PM
vandersmissenc's Avatar
Default Re: Weird Idle Loop (slacks)
umm i believe it is the fitv but it might be the iacv, search on them and the one that has a white ring inside is one you can check. Search for idle hunt and it should come up and tell you how to tighten the white screw, thats a problem for alot of people, just a suggestion though
Old Oct 11, 2007 | 07:36 PM
slacks's Avatar
Default Re: Weird Idle Loop (vandersmissenc)
i've adjusted the screw on the iacv but what is the fitv?
i'm definately looking into this more
thanks
Tillerdrums88
Jan 14, 2013 07:55 PM
vodkaTM
Jul 31, 2009 09:08 AM
easycheese
Jan 14, 2008 10:04 AM
Creepshow S60
Aug 29, 2004 06:36 PM
Civic Racer X 7
Jul 23, 2003 07:19 AM
