Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
blower transistor issue
Old Oct 11, 2007 | 02:46 PM
feindre's Avatar
Default blower transistor issue
A few days ago my blower fan stopped working abruptly. I narrowed the problem down to the blower transistor not functioning, so I replaced it with a new one. It worked for about 10 minutes before it also stopped working. I got a recommended ohm rating on the 4-pin connector itself, so the part isn't getting too much power. I'm not sure what else could be happening here, but the ground pin is NOT being affected by the blower switch on the dashboard. Could the transistor be getting so much grounding that it burns out due to it? Even if that's the case, I don't know what to do to fix it. Please help!
Old Oct 11, 2007 | 09:16 PM
toyomatt84's Avatar
Sanji
Default Re: blower transistor issue (feindre)
Welcome to Honda-Tech.
First, read this: https://honda-tech.com/zerothread/2101211
It'll tell you to go here: https://honda-tech.com/zerothread/1759217
Where you'll find this: https://honda-tech.com/zerothread/2041582
john79
May 25, 2018 05:04 AM
mrader
Dec 10, 2008 04:53 AM
f@sth@tch89
Aug 31, 2008 03:43 AM
hybridclassic626
Sep 15, 2007 05:49 PM
POS89CivicLX
Jun 24, 2002 09:33 PM
