94 ls wont start
So I broke my foot and didn't drive my 94 ls for 2 months and now it will not start. Here is a breakdown of some stuff I have looked at.
-checked all the fuses they look fine
-engine is turning over
-all four spark plugs are producing sparks
-fuel pump is pumping and hoses are not clogged
I don't know what else to check really. The injectors are squirting kind of funny so my buddy Frozty is bringing me some from his house to try and use.
Do you all have any other suggestions? Thanks in advance.
Put a half a cap of engine oil in each cylinder, let sit for a few minutes, crank engine with plugs out for several seconds, put a rag over the spark plug holes, put back together and see if it starts. Can you make spark jump 1/4 inch or a little more?
My dad checked the spark plugs (I was in the car), I am assuming the spark jumped that much. I will give that a try when my buddy gets here though! Thanks, I am sure the engine needs lubrication since it sat for so long and is so old (190k).
Lei Siew Long
Jul 16, 2001 02:45 AM
