EG and EK tranny question...
Old Oct 11, 2007 | 11:07 AM
stratedrm's Avatar
Default EG and EK tranny question...
My 96 dx has a slipping clutch.. and the tranny is grinding in reverse alot..
but i have my 95 dx motor leftover from my swap..
i should be able to bolt the eg tranny and clutch up on my ek right? i just need to keep the same mount right?
Old Oct 11, 2007 | 11:15 AM
crazyguy's Avatar
Default Re: EG and EK tranny question... (stratedrm)
yeah all d series tranny are compitable..i used to run a d16z6 engine with 2000 civic ex tranny..no problem and for your reverse grinding..it is normal for a honda tranny..there is nothing u can do about it...cause it does not have any sychro...try to shift into 2nd gear first then shift to reverse..
Old Oct 11, 2007 | 08:07 PM
stratedrm's Avatar
Default Re: EG and EK tranny question... (crazyguy)
i would keep the ek axles if i'm using an eg tranny still?
forcefedferio's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stratedrm &raquo;</TD></TR><TR><TD CLASS="quote">i would keep the ek axles if i'm using an eg tranny still?</TD></TR></TABLE>
yep, you can.
allmotorlsbaby
Mar 17, 2009 11:58 PM
stratedrm
Oct 11, 2007 12:59 PM
marksae
Jun 6, 2007 09:20 AM
prjctCIVIC
May 28, 2007 06:40 AM
604nguyen
Sep 26, 2006 02:17 AM
