Weird Squeaking Noise Coming From Suspension......????
Old Oct 11, 2007 | 08:55 AM
Riga89's Avatar
Default Weird Squeaking Noise Coming From Suspension......????
What's up all,
I've got a 2000 Honda Accord SE (same car as in signature). About a month or so ago, I noticed a weird (and very annoying I might add) squeaking sound whenever driving. I had all four struts replaced with Monroe OEM Struts. This did not fix the problem.
Whenever I'm going over bumps and badly paved roads the squeaking intensifies. When I’m driving on smooth paved roads the squeaking does not occur. This squeaking does not affect the performance of the car but it's very, very, annoying. The sound is not loud, but I'd like to fix the problem as soon as I can locate the source.
The car was involved in a front end collision earlier this year, but the squeaking comes from the back too. I'm thinking maybe it’s the ball joints. I'm not thinking CV joints b/c what I've read on the internet does not correspond with my problems.
Thanks in advance. PLEASE HELP!!!
Old Oct 11, 2007 | 09:03 AM
lunarone's Avatar
Default Re: Weird Squeaking Noise Coming From Suspension......???? (Riga89)
A month ago, did the weather start cooling down to colder temperatures? During the winter, I notice the same noises you are mentioning, and I believe it is due to the bushings in the suspension just being cold. From what I hear, you can lube up the bushings and it should decrease the noise. Maybe this is part of your issue?
Old Oct 11, 2007 | 09:22 AM
TouringAccord's Avatar
H-T Order of Merit
http://members.troublecodes.ne...s.htm
http://syclone.motocrew.com/CG5/swaylube.htm
Try that and see if it helps.
both located in the Accord FAQ
Old Oct 11, 2007 | 09:44 AM
Riga89's Avatar
Default Re: Weird Squeaking Noise Coming From Suspension......???? (TouringAccord)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lunarone &raquo;</TD></TR><TR><TD CLASS="quote">A month ago, did the weather start cooling down to colder temperatures? During the winter, I notice the same noises you are mentioning, and I believe it is due to the bushings in the suspension just being cold. From what I hear, you can lube up the bushings and it should decrease the noise. Maybe this is part of your issue?</TD></TR></TABLE>
I have stock suspension, nothing aftermarket. I don't think I have a swaybar. Please continue with the suggestions.
Old Oct 11, 2007 | 10:10 AM
H-T Order of Merit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Riga89 &raquo;</TD></TR><TR><TD CLASS="quote">I have stock suspension, nothing aftermarket. I don't think I have a swaybar. Please continue with the suggestions.</TD></TR></TABLE>
You dont think or you know for sure? You may want to go double check by looking under your car.
After looking at some diagrams on SLHonda you should have a 26.5mm sway bar in the front and a 16mm sway bar in the rear.
Old Oct 11, 2007 | 11:48 AM
The-Kid's Avatar
Yup i had this problem. Some greasing of the swaybar bushing made it go away. And yes your car does have front and rear swaybars.
AcCO12D95
Feb 15, 2018 04:59 PM
josephemorgan91
Honda Civic (2001 - 2005)
Dec 14, 2015 07:19 PM
gchino
May 23, 2006 08:51 AM
WPG_5thgenprelude
Jan 11, 2005 03:37 PM
Mike813
Jan 14, 2004 01:27 PM
