Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
Tin can noise from front passenger side - 07 Si Sedan
Old Oct 11, 2007 | 08:48 AM
twentywontowin's Avatar
Default Tin can noise from front passenger side - 07 Si Sedan
My first thread in this forum but a lot of you will recognize me from Kills/GDD.
I purchased a new 07 Si Sedan last month, has a shade over 1000 miles on it.
Today I was driving to work, and I noticed what I would describe as a tinnish sounding clunk coming from my front passenger side when I go over slight bumps. I'm thinking it's a problem with the shock or strut assembly. It's definitely not the popping noise that other owners have noticed.
Is this something anyone else has experienced? I tried finding a TSB for it but to no avail. It will be going in under warranty but I wanted to see if anyone else has noticed a similar problem.
Thank you.
Old Oct 11, 2007 | 08:52 AM
exhaust_note's Avatar
yea it sounds like somethings tapping in the fender. i just turn the music on.
Old Oct 11, 2007 | 08:55 AM
Default Re: (exhaust_note)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by exhaust_note &raquo;</TD></TR><TR><TD CLASS="quote">yea it sounds like somethings tapping in the fender. i just turn the music on.</TD></TR></TABLE>
That's why I couldn't hear it either.
Old Oct 11, 2007 | 08:58 AM
RICO_'s Avatar
NO MERCY!
Default Re: Tin can noise from front passenger side - 07 Si Sedan (twentywontowin)
Sure you didn't leave a soda can in the door pocket??
j/k. Just take it in and have the dealer look at it. Most likely it's just a bad strut and they can replace it.
Old Oct 11, 2007 | 09:00 AM
ive got comptech springs.. they wont touch it.
Old Oct 11, 2007 | 05:29 PM
yed's Avatar
yed
Service bulletin for a bump stop. It shouldn't matter if you have aftermarket springs, seeing as the dumb *** techs at my Honda dealer replaced my stock springs 3 times in a row and it didn't solve the problem at all.
Old Oct 11, 2007 | 07:11 PM
Default Re: Tin can noise from front passenger side - 07 Si Sedan (yed)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yed &raquo;</TD></TR><TR><TD CLASS="quote">Service bulletin for a bump stop. It shouldn't matter if you have aftermarket springs, seeing as the dumb *** techs at my Honda dealer replaced my stock springs 3 times in a row and it didn't solve the problem at all.</TD></TR></TABLE>
thats not the sound.. i have that to.
thats more of a popping noise.
it actually sounds like an empty soda can is tingling around in the fender.
Old Oct 11, 2007 | 07:17 PM
cnyej1's Avatar
Default Re: Tin can noise from front passenger side - 07 Si Sedan (exhaust_note)
I had this sound and it sounded like metal rattling. Anyhow if I pushed down on the pass side airbag at the very corner where it makes a seam with the rest of the dash I could replicate it. So the Techs put some felt in between the airbag and the mount and then they went underneath the dash through the glovebox and taped up the heater pipe because that was rubbing too. The sound is almost completely gone.
Old Oct 11, 2007 | 07:19 PM
Default Re: Tin can noise from front passenger side - 07 Si Sedan (cnyej1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cnyej1 &raquo;</TD></TR><TR><TD CLASS="quote">I had this sound and it sounded like metal rattling. Anyhow if I pushed down on the pass side airbag at the very corner where it makes a seam with the rest of the dash I could replicate it. </TD></TR></TABLE>
I'lll have to look into that. Thanks
Old Oct 11, 2007 | 08:12 PM
yed's Avatar
yed
it actually sounds like an empty soda can is tingling around in the fender.</TD></TR></TABLE>
Ohhh like a can being rattled around, not being hit. That sucks
Trackready
Apr 27, 2013 08:09 PM
nickzed20
Mar 31, 2006 05:44 AM
djnikko
Honda S2000
Apr 27, 2004 03:37 PM
