Suspension & Brakes Theory, alignment, spring rates....
typical suspension noob
Old Oct 10, 2007 | 07:48 PM
92VXeg's Avatar
Default typical suspension noob
I've got a 92 civic hatch on some god know what coilovers...They are probably dropped 2.5-3inches. But its time for an upgrade. I want to get the whole thing replaced with new stuff all the way around and still be able to have the 3inch drop and still ride comfortably.
Of course best bang for your buck setup. I dont do any autocross. Just everyday street car with more track use as the money comes in.My budget is $850.
I dont know a whole lot about suspension and dont make my way into this forum often so this is probably a question thats asked pretty regularly/has been beaten to death. so if ya can give me any input..maybe just help me find a link. thanks
Old Oct 10, 2007 | 07:59 PM
Guam_CiviC619's Avatar
Default Re: typical suspension noob (92VXeg)
Try AMR engineering, they are within your price range, and they can provide you with soft spring rates with a properly valved damper that has a lifetime warranty. Although I must admit you start running into "issues" once you start to lower your car within your target ride height, such as slamming your upper control arms on the shock towers, rubbing, and possibly bottoming out due to soft spring rate, although if you roll where roads a smooth as glass, then you shouldn't have any issues. You may want to hurry with your order cuz I just read that they are about to raise prices because of increased prices of manufacturing materials.
https://honda-tech.com/zerothread?id=1659160
Targa250R's Avatar
be professional
Low height, comfortable ride, competent handling. Pick two. You can't have all three, especially for $850. What is important to you?
Why is it "time for an upgrade"? What problems or shortcomings are you having with your existing coilovers?
Old Oct 10, 2007 | 10:02 PM
gsrob's Avatar
Default Re: typical suspension noob (Targa250R)
Targa is right. There are many, many options. Just read through some of them. It sounds like you are going to have to compromise though on certain things if you want your car that low...
Old Oct 11, 2007 | 05:23 AM
92VXeg's Avatar
I dont know how much of a drop im looking for but with the top of the tire even with the lip of the fender is what it is now and would want that back. The person before me traded the coilovers on the front for cut springs (dont know why) and I want new stuff all the way around cause its making a wierd rattling noise on the passenger side that has gotten worse over time. its like everytime i hit a bump that dips down or if im going like 5mph through a parking lot and tiny bumps just rattle it and it sounds like crap.
sound like a heat shield rattling but its not. Im not looking for the best handling. Just dont want the handling to get worse but i figure that with new stuff that it cant get any worse
Old Oct 13, 2007 | 08:02 AM
jcochran's Avatar
if you're only going three inches there are ways around the shocks bottoming out, and the upper control arms hitting the inner fender/shock tower, its just going to take more work. You should be able to get a good ride out of a car at that height.
Extended top hats and search for the "fork trick", both of those will help with more suspension travel if its that important to you.
carracr625
Jul 7, 2004 03:21 PM
vti444
12
Nov 10, 2003 11:14 AM
Peters1983
Sep 24, 2003 06:38 PM
itr1236
Mar 6, 2003 09:13 PM
