how many....(amsoil)
i would just like to know how many "Quart Bottles" of AMsoil would i need for the engine and tranny...
also i was wondering 5w-30 or 0w-30, and what type of AMsoil mtf type do i need.
PRETTY MUCH... What are ppl using for their Si's?
thanks
thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ekb16 »</TD></TR><TR><TD CLASS="quote">engine takes about 5.2qts of 5w-30
tranny takes about 2-3qt</TD></TR></TABLE>
negative, engine takes exactly 4.6 quarts, read your manual, damn.
and i use amsoil and love it. doing the tranny soon with amsoil as well.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by d3xt3r19 »</TD></TR><TR><TD CLASS="quote">i would just like to know how many "Quart Bottles" of AMsoil would i need for the engine and tranny...
thanks</TD></TR></TABLE>
tranny takes 1.8 quarts and makes the car shift like a dream
motor just get 6 quarts to have extra on hand but its some where in the nature of like 5 to fill it up
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by "Ridge"Racer »</TD></TR><TR><TD CLASS="quote">
and i use amsoil and love it. doing the tranny soon with amsoil as well.</TD></TR></TABLE>
it says 4.6 in the manual but u try puttin 4.6 in, start ur car for a few sec., shut it off and check ur dip stick..it will be alittle above the 1st dot..i do oil changes on the new SI at least 2x a week at work (honda dealership) so i think i know what im talking about
thank you guys for your replies.... but
what about my mtf, i know i'm going to choose amsoil but what type... and also there are so many other choices for the engine oil on amsoil online that i just want to know whats the best to use. Both mtf and engine.
i just need a little more help... i just want to get this done right, thats all.
thanks again
thinking of using...
https://www.amsoil.com/storefront/atm.aspx (engine)
https://www.amsoil.com/storefront/mtf.aspx (mtf)
yes???
Modified by d3xt3r19 at 10:19 PM 10/12/2007
Modified by d3xt3r19 at 11:38 PM 10/12/2007
thanks again
yes???
All the products that AMSOIL sells are great the best motoroil is the 0W-30 that oil is actually used in race cars and is able to with stand the highest heat.
Check out infor on this website I found some intersting articles about many products that AMSOIL sells. http://www.easymotoroil.com
As far as the transmisson fluid the one you said is great you can also look up the specific products that are you can put into your vehicle by going to this link then you can scroll down to the bottom and it tell you all the products you can use and how much to use if each product.
http://www.amsoil.com/products...83153
I hope this was of some help
it says 4.6 in the manual but u try puttin 4.6 in, start ur car for a few sec., shut it off and check ur dip stick..it will be alittle above the 1st dot..i do oil changes on the new SI at least 2x a week at work (honda dealership) so i think i know what im talking about</TD></TR></TABLE>
yeah but do u wait for the oil to drain back to the pan, and u don't want to over fill the engine being that u can damage it if u do.
good rule of thumb, just follow manufactur specs and then check level "AFTER" u let it drain back down.
Yeah, I took my Si to a supposed independent Honda specialist. I provided him with 5 qts of Amsoil 5w-30(ASL) thinking he'd know the capacity is 4.6 qts being a "specialist" and all.... When he was done, I asked him for the remaining half(.4) quart of oil, and he told me that he put all 5 qts in. He said that was normal and that the engine could actually use a little more,LOL! I showed him that the owners manual said that the capacity is 4.6 qts. He said noooooo, that he does this everyday, blaa, blaa, blaa.... I drove home and let the car sit about 45min. I went out and checked the oil, and it was over the max/full hole(indicator) by almost a 1/4". I took the car back to the "specialist" and told him it was overfilled. He looked none to happy(like I was trying to be dick or saying "I told you so"), but drained a little Amsoil out(wasted) for me. I'm never going back there again..... I highly recommend Amsoil oil, but the Synchromesh MT fluid is a must!
Amsoil is by far one of the best oils I've ever used. My car use to burn 1 quart of oil at about 7000 miles before my scheduled oil change of 15,000mile and when I started using Amsoil...I reach my oil change interval at 15,000 miles without adding any oil. Before this experience, I always thought there weren't much differences between oils.
not to thread jack but this regards changing the trans fluid. i noticed the drain bolt sits pretty high up compared to where the bottom of the bell housing sits.. anyone decide to drain the trans through a casing bolt?
eugene_fender
12
May 24, 2007 08:33 AM
Nexx
Apr 2, 2005 02:19 PM
