91 accord ex auto tranny problem
Old Oct 10, 2007 | 07:01 PM
zeroice's Avatar
Default 91 accord ex auto tranny problem
ok heres whats going on. Reverse was bad so when i coverted my other accord from auto to manual i had the tranny to swap out with this accord with a bad reverse... everything goes good slap it back together go to crank it and the solenoids on the tranny click when i go to start it and then thats it... starter doesnt engage. Now i checked my ground and all are good everything is pluged in i have swapped motors and trannies in over 10 hondas so its not something new to me. I made sure the starter worked by running a wire from the battery to the starter and it turned over no problem. also checked spark at the same time and have none. I know its something to do with electrical but i need some suggestions on what to check. I know its in park neutral safety switch works. Its late but i dont think the fuel pump even primes. Now before the swap everything worked fine besied the reverse and now the solenoids on the tranny click when i turn the key to the start position and thats all it does..
Thanks for any and all help...
Old Oct 11, 2007 | 07:53 AM
Ross 2.0's Avatar
In a Junkyard near you.
Ground on the thermostat housing?
Old Oct 11, 2007 | 07:58 AM
sony224422's Avatar
Default Re: (Evil M0nkey)
if you pull off the neg. cable on the battery will the solenoids click again? if so you have something reversed..
Old Oct 11, 2007 | 07:27 PM
zeroice's Avatar
Default Re: (sony224422)
didnt undo the ground on the thermostat only undid the connectors on the tranny and main harness on car... will have to try the battery cable tomorrow but i did nothing different its a plug in play swap only changed the tranny nothing else.
Old Oct 19, 2007 | 05:42 PM
zeroice's Avatar
Default Re: 91 accord ex auto tranny problem (zeroice)
anybody else
rkmartin017
Jul 21, 2012 07:34 PM
killerkali420
Mar 30, 2011 04:29 PM
phantom_bcw84
Oct 2, 2010 08:04 PM
efjones9
18
Mar 11, 2010 12:53 PM
wyldbil
Jun 2, 2004 06:35 PM
