Suspension Setup
Old Oct 10, 2007 | 06:05 PM
lude98SH's Avatar
Default Suspension Setup
Ive been looking at different FWD suspension setups for awhile now. And the way most ppl go about it seems like parts are mismatched and their setup is not suited well for their application. On a fwd car, it will be more prone to understeer. To reduce understeer you can stiffen rear sway bars as well as springs. The opposite is true for RWD, they will tend to oversteer. And you will generally tighten up the front end to counteract it. Or drop the tire pressure in the rear to give yourself a greater contact patch.
However i see most ppl just getting the stiffest possible rates and stiff rear sway bars. Isnt one working against the other ? Wouldnt you want to go soft up front with your springs? Or is their a point to where u go so stiff in the rear that you have to counteract it with stiffer springs up front ? Somebody with experience on fwd please comment. The application will be for circuit or autox.
Old Oct 10, 2007 | 06:09 PM
mgags7's Avatar
There is a suspension forum. Plenty of info there.
Old Oct 10, 2007 | 06:11 PM
lude98SH's Avatar
Default Re: (mgags7)
yea true ill post up there i guess. Should be pretty similar between hondas (besides S2k)
Old Oct 10, 2007 | 06:16 PM
InvaderTrax's Avatar
To be honest, my H&R Sport springs on KYB GR-2 shocks with stock sway bars and 215/40/17 Kumho ASX tires was incredibly neutral. It would only understeer if I absolutely cut the wheel at 40mph
Old Oct 10, 2007 | 06:18 PM
mgags7's Avatar
Default Re: (InvaderTrax)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by InvaderTrax &raquo;</TD></TR><TR><TD CLASS="quote">To be honest, my H&R Sport springs on KYB GR-2 shocks with stock sway bars and 215/40/17 Kumho ASX tires was incredibly neutral. It would only understeer if I absolutely cut the wheel at 40mph</TD></TR></TABLE>
How many times have you driven your car on a track? Driving on the street does not give an accurate description of a car's handling at the extreme.
mmag2982
Jun 19, 2015 11:08 AM
hey man
14
Sep 14, 2011 02:28 PM
jdm_dc_fan
Honda Civic (2006 - 2015)
23
Oct 29, 2008 02:07 PM
NTGR8D
Mar 7, 2005 09:17 PM
