Performance General Performance oriented Parts (Ex: Camshafts, Electronics, Air Intakes, Exhausts, complete engines)
FS: TDM Race header dyno proven (B-series)& Cross bar (X) for the EK/DC CHEAP
Old Oct 10, 2007 | 04:21 PM
sublimnal's Avatar
Default FS: TDM Race header dyno proven (B-series)& Cross bar (X) for the EK/DC CHEAP
TDM Products 4-2-1 Tri-Y Production Headers (HyTech Replica)
* TRI-Y HEADER SALE * Hytech Style 4-2-1 Production Header $350 SHIPPED for all H-T Members!
Optional Titanium Nitride Coating Available. Limited Supply.
HEADERS IN STOCK~!! GET THEM WHILE WE GOT THEM!
Price will increase due to low supply and high demand.
4-2-1 Production Tri-Y Stainless Steel Header (B Series)
Best Production Header On The Market Today!
This is THE MOST AFFORDABLE header on the market today that will outperform ANY header in the same price range.
Fits ALL B-Series Engines Honda/Acura. All B18(A/B/C1/C5), B16, B20 Honda Engines.
Clears Dual Core Radiators, Works with Power Steering & AC unlike other designs.
NOTE:
1) Does not fit EF (88-91 Civic) chassis with factory crossmember, modifications will be required. (May fit with aftermarket crossmember / traction bar.)
2) Does not fit with factory Type R transmission / motor brace, transmission brace can be swapped with GSR/LS/B20.
3) Does not fit with DA chassis. Will need possible modification to x-member and/or A/C bracket.
Due to the long tube design for performance, this header will eliminate stock catalyst converter and meant for racing only. It may require an extension pipe in order to bolt into your factory or aftermarket exhaust system.
• 304 Stainless Steel (Brushed)
• Warranty against cracking
• High Flow Tri-Y Merge Collector
• Hand TIG weld
• CNC machined flange
• High Flow True 2.5" merge collector
• BRAND NEW IN RETAIL BOX
• Best Ground Clearance
• Long Tube Design.
Guarantee fitment & quality ! Money back guarantee dyno proven!
This replica header is just like any other HyTech replica header out there on the market today that sells for $600+
PayPal ID : HONDAPARTSALES@GMAIL.COM
(Confirmed Address ONLY)
** FREE FedEx Express Saver Shipping on ALL ORDERS. Get your header within 1 to 3 business days.
For a limited time, we'll include:
• FREE OEM spec header gasket - $30 value
• FREE OEM spec 2.5" donut gasket - $20 value
* Header Mounting Point Bracket
PayPal ID: HONDAPARTSALES@GMAIL.COM
We're seeking for reseller partners (REQUIRES A BUY-IN). Please send me an email to HONDAPARTSALES@GMAIL.COM
__________________________________________________ ________________________________________
Titanium nitride (Ti-N) coating available for ONLY $50 option (valued at $150)
Similar to the Jet Hot coating and other coating companies…the benefits includes:
• Extends header life dramatically, Ti-N coating makes the 304 S/S stronger.
• Reduces header-surface temperatures. Keeps the heat inside and out to the exhaust.
• Cuts engine bay heat, lower under the hood temperature.
• Last but not least, The “BLING” Effect. Ti-N shines like GOLD, once heated it turns into multi-color like the Japanese made titanium shift ***** you see on the market today.
<FONT SIZE="2">The "Bling" Effect in Full Effect </FONT>
[b]Others charge $150+ per header JUST FOR COATING. We only charge $50. LIMITED AMOUNT AVAILABLE, WHILE SUPPLIES LAST.[b]
Much thanks to DNR Performance in Hayward, Calfornia. We now have a dyno chart for you guys.
"just picked up this header last week and tested on a '95 civic hb w/ a usdm itr motor. i was pretty impressed by the gains...
mods:
B18c5
port n polished head
stg 2 cams, gears, and valve train
port matched intake mani. & 70mm tb
chipped p28, adj. fpr. 255lph pump
AEM ITR CAI, JDM 4-1 headers/hytech replica
only thing changed between runs was the header
made back to back runs, no tuning before or after the header swap"
A 14 whp gain over the JDM 4-1. Need I say more? This is the BEST header for the price.
Extension pipe available for purchase as an option at only $30 ($70 value).
This piece goes over the 2.5" collector and to your B-pipe exhaust. It completely get rid of the cat and act as a test pipe.
<FONT SIZE="2"> Ground Clearance pics</FONT>
Contact Me Via PM or Email at HONDAPARTSALES@GMAIL.COM For more info!
Or just reply here and I'll try and have your questions answered asap!
Paypal ID : HONDAPARTSALES@GMAIL.COM
**CONFIRMED ADDRESSES ONLY**
<FONT SIZE="4">TDM Miracle Style X-Bar (Cross Bar) Blow Out Sale for the DC Integra & EK Civic </FONT>
<FONT SIZE="3">Price is $250 shipped for all H-T members. </FONT>
<FONT SIZE="2">**FREE FedEx Shipping on ALL ORDERS!*** </FONT>
***CONFIRMED ADDRESSES ONLY***
<FONT SIZE="3">The Basics:</FONT>
• utilizes the c-pillar and strut points to decrease body flex during hard cornering
• maximizes 4 critical points of the chasis to 1 stress point
• While having a stylish look to your car where no has had at an affordable price
made of SUS304 stainless stainless steel (aircraft steel)
• utilizes rear seats(for most applications)
• Improvement is undeniable, you will feel the difference instantly when installed
for maximum rigidity
• Made of high grade aircraft SUS304 stainless steel(18 gauge).
<u>Fits Integra DC Chassis 1994-2001</u>
<u>Fits Civic Chassis 1996-2000 (EK4-EK9)</u>
<FONT SIZE="4"><u>ALL PRODUCTS ARE NEW IN BOX~!</FONT></u>
<FONT SIZE="4"><u>EVERYTHING IN STOCK & READY TO SHIP! INVENTORY PHOTO BELOW:</FONT></u>
<FONT SIZE="3"><u>For more information PM me or send me an email at HONDAPARTSALES@GMAIL.COM or reply to the thread and I'll have your answers ASAP</FONT></u>
<FONT SIZE="3">PAYPAL PAYMENTS TO: HONDAPARTSALES@GMAIL.COM</FONT>
Modified by sublimnal at 2:55 PM 10/12/2007
Old Oct 12, 2007 | 12:11 PM
sublimnal's Avatar
Default Re: FS: TDM Race header dyno proven (B-series)& Cross bar (X) for the EK/DC CHEAP (sublimnal)
bumping it for the fridays
Old Oct 12, 2007 | 05:36 PM
kblus711's Avatar
Default Re: FS: TDM Race header dyno proven (sublimnal)
Any Other H-T members have any feed back on this header?
Old Oct 15, 2007 | 11:28 AM
sublimnal's Avatar
Default Re: FS: TDM Race header dyno proven (kblus711)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kblus711 &raquo;</TD></TR><TR><TD CLASS="quote">Any Other H-T members have any feed back on this header?</TD></TR></TABLE>
i have sold over 200 of these babies
Old Oct 15, 2007 | 01:47 PM
kblus711's Avatar
Old Oct 15, 2007 | 06:26 PM
sublimnal's Avatar
check out my thread in my signature i have a sponsored sellers thread
Old Oct 16, 2007 | 11:35 AM
sublimnal's Avatar
Taco tuesdays ?
Old Oct 16, 2007 | 01:08 PM
iH8RICERZ's Avatar
BUMP cause I think I'm gonna eventually get one of those X bars...!
Old Oct 18, 2007 | 02:36 PM
sublimnal's Avatar
thursday bump
Old Oct 19, 2007 | 04:33 AM
George Knighton's Avatar
H-T Order of Merit
This is not the right place for commercial posts.
Old Oct 22, 2007 | 05:36 PM
H-T Order of Merit
Old Apr 7, 2010 | 09:18 AM
tnxx's Avatar
how much for just the donut gasket 2.5" ID shipped to 63116?
TDM Products
Performance
1412
Mar 12, 2015 03:26 PM
Top Ramen
51
Aug 27, 2009 07:45 PM
sublimnal
Northern California (Sales)
Oct 30, 2007 05:43 AM
yellowbananaitr
44
Aug 7, 2007 11:25 PM
