Can you identify my clutch?
Hi... i recently bought this clutch pressure plate and disc... i paid $40 dlls for both. It is supossed that this is a heavy duty kit... but i would like to know what brand it is. As you can see, it is used... but in good shape. When it was installed, the clutch pedal was stiffer than the OEM is.
Well... here are some pictures, so you can name it. Thanks in advance.
Side 1.
Side 2.
Both sides.
Check the inserts.
The pressure plate
Check the double "diaphragm" (I dont know if it is called this way)
And there is a code... i searched this code in google... and here in honda tech... and could not find any info about clutch kits or something alike.
Side 1.
Side 2.
Both sides.
Check the inserts.
The pressure plate
Jajajajajaja, lmao... jajajaja.
That was so funny, but true. Thank you for your answers.... that is exactly the kind of info i was expecting from you.
And yes... the clutch pedal is very stiff.
Would having that stiff of a clutch mess with the crank at all? I've heard Mitsu's used to have a problem with crank walk on cars with heavy pressure plates. At least that's what the guy from ACT said when i got my Xtreme.
crazyguy
Jun 21, 2007 08:11 AM
kaptr1d
45
Jan 3, 2005 09:49 AM
arren123
Jul 4, 2002 07:19 PM
