Warranty?
Old Oct 10, 2007 | 01:27 PM
ek-j's Avatar
Default Warranty?
Ok so I took my EP3 for warranty work last week, because my ac went out.
I took everything off the car.. Headers, intake, exahust, but I forgot to change the srpings. Well they fixed the AC, and took the car for a test drive. They told me the heard a noice comming from the front suspencion, so they decided to check it out. To make the story short they voided my entire suspension warranty because of the srpings. Now my question is, Can they do that? I didn't ask them to check my suspension, I just wanted my ac worked on, and there is no noice comming from the front...That is bull ****!
If something happends to the suspension, can I take it to another Honda dealer?
Modified by ek-j at 10:53 AM 10/11/2007
Old Oct 10, 2007 | 01:35 PM
Duane_in_Japan's Avatar
Default Re: Warranty? (ek-j)
You made modifications from OEM, that voids a warrantee, guilty as charged. Can you put it back to OEM and see if your warantee is voided in the Honda database at another dealer, end of story for the suspension.
Old Oct 10, 2007 | 01:54 PM
ek-j's Avatar
Default Re: Warranty? (Duane_in_Japan)
I know that, but I did not ask them or authorize them to work on my suspension. There isn't anything wrong with my suspension.
Old Oct 10, 2007 | 02:36 PM
risktypeS's Avatar
they're not suppose to work on any different part of the car without notifying you first. I bet if you tell them to either 1 put it back to how you had it or 2 you'll get a lawyer and bring this into court they'd have a different attitude. This is just like taking your car in for an oil change and they end up changing everything they see wrong and then charging you for it when you did not ask. It is illegal. They did not have your consent to make those changes and if it was noted (which it should be) that you took it in for work on just the A/C then they have to only work on what it was brought in for.
Modified by risktypeS at 4:59 PM 10/10/2007
Old Oct 10, 2007 | 03:20 PM
dan12288's Avatar
Default Re: Warranty? (risktypeS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by risktypeS &raquo;</TD></TR><TR><TD CLASS="quote">they're not suppose to work on any different part of the car without notifying you first. I bet if you tell them to either 1 put it back to how you had it or 2 you'll get a lawyer and bring this into court. This is just like taking your car in for an oil change and they end up changing everything they see wrong and then charging you for it when you did not ask. It is illegal. They did not have your consent to make those changes and if it was noted (which it should be) that you took it in for work on just the A/C then they have to only work on what it was brought in for. </TD></TR></TABLE>
i agree, they should have first question you about the suspension before they did anything to it.
Old Oct 10, 2007 | 10:21 PM
Many shops give a free undercar, or where ever, inspection, its an attempt to make an upsale, its a business trait, there may be a sign in the shop, it may be part of your contract, they are allowed to look things over to attempt to make more money, not from you but from the Maker, warantee work, recalls, TSBs that you dont have to pay for. It happens all the time, work that you didnt authorize and you do not have to pay for, but again, they may try at times to get your money and they may find problems that need attention right now, for real.
I do not think you have a case but you can at least inquire about it.
Old Oct 11, 2007 | 02:44 AM
risktypeS's Avatar
it's required to be notified for each problem they are to work on or need to work on.
Old Oct 11, 2007 | 09:27 AM
WhiteOnRice's Avatar
Tell them to put your springs back on.
You can look through the rims and see if someone put aftermarket springs on. I'm sure they knew about it while working on/test driving the car. Your suspension should be voided but they should not have changed your springs.
Old Oct 11, 2007 | 09:38 AM
Type-Slayer's Avatar
This story doesn't sound right. It is illegal for them to do work without your permission, but this is a very big mistake, that a dealership would not make. I think you have left a part out of this story.
Old Oct 11, 2007 | 09:53 AM
ek-j's Avatar
Default Re: Warranty? (Type-Slayer)
Sorry for the misunderstanding!
They never changed my springs.. I meaned they fixed the ac not the springs. I took it in for ac work, and they said that there was a noise comming from the susp. They started to check it out without my permission, and then noticed the springs. They called me and told me the susp warranty was voided, but they didn't charge for anything.
Old Oct 11, 2007 | 10:06 AM
Thats sucks, but sounds perfectly legal.
Old Oct 11, 2007 | 12:31 PM
risktypeS's Avatar
oh ok.. that sounds a lot better. you were missing some points to the story but sounds right.
fryman
Suspension & Brakes
24
Dec 8, 2009 10:07 PM
vti444
Jun 10, 2008 10:36 PM
Tippyman
Sep 2, 2006 01:24 PM
Flux
Dec 1, 2003 04:11 PM
