Carb'd B-Series.... in a corr super buggy!!!
damn that thing is pretty sick pretty interested to know what trans you are using as well.
we built a B20 Vtec turbo 2 seater sandrail right now . trans we are using is a VW bus trans with kennedy adapter plate, Accel DFI for engine management. t3/t4 setup.
It uses a Mendeola 2D transaxles....
"Mendeola Transaxles sells more MD4-2D units than any other model, affectionately known by trans builders and duners alike as the ‘2D.’ The 2D is the most used aftermarket transaxle in the recreation vehicle market. Almost every sand buggy and off-road chassis manufacturer has the 2D available on their line as standard equipment or an option. There are three choices of ring and pinion ratios combined with 17 main shaft sets (1st and 2nd), thirteen 3rd gears and twenty 4th gears making this model a ‘Universal Fit.’"
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MugenGTR »</TD></TR><TR><TD CLASS="quote">It uses a Mendeola 2D transaxles....
"Mendeola Transaxles sells more MD4-2D units than any other model, affectionately known by trans builders and duners alike as the ‘2D.’ The 2D is the most used aftermarket transaxle in the recreation vehicle market. Almost every sand buggy and off-road chassis manufacturer has the 2D available on their line as standard equipment or an option. There are three choices of ring and pinion ratios combined with 17 main shaft sets (1st and 2nd), thirteen 3rd gears and twenty 4th gears making this model a ‘Universal Fit.’"</TD></TR></TABLE>
Yeah the Mendeolas are great trans... just VERY heavy on your wallet!!!!!!!!
Didnt think HT would be interested in race buggies w/ honda motors.... but since you guys seem to be... here's a few more that are powered by B16a motors
b16a are pretty popular w/ class 10 buggies because the class limits engine displacement to 1600cc, orginally intended for 1600cc vw motors...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MugenGTR »</TD></TR><TR><TD CLASS="quote">i know kennedy does....
http://www.kennedyeng.com/</TD></TR></TABLE>
thats where i got mine.....
Munkyw3rkz.webs.com
unique..... but i would like some info on the motor.... are there rules as to why they are using just 1 carb?
that carb is killing power working alone....
also i would assume its on vtec killer cams since you cant tune for the high/low cam with carbs.....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by S@nt0s »</TD></TR><TR><TD CLASS="quote">unique..... but i would like some info on the motor.... are there rules as to why they are using just 1 carb?
</TD></TR></TABLE> Why not? You just need a good supply of emulsion tubes.
Munkyw3rkz.webs.com
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DonF »</TD></TR><TR><TD CLASS="quote"> Why not? You just need a good supply of emulsion tubes. </TD></TR></TABLE>
i am asking more about the motor.... i wanna know what size carb that is 40/45/50/55?? i know its a weber that much i can tell in the pic....
but the flow with just 1 is hurting power in the upper revs
</TD></TR></TABLE> Who cares? If everyone has the same size carb and chokes, THAT be the rules. Takes a little more work than just buying parts off E-bay, but much more satisfying.
Munkyw3rkz.webs.com
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DonF »</TD></TR><TR><TD CLASS="quote"> Who cares? If everyone has the same size carb and chokes, THAT be the rules. Takes a little more work than just buying parts off E-bay, but much more satisfying. </TD></TR></TABLE>
yes i know that.. which is why i asked
and what does buying anything off ebay have to do with this?
Munkyw3rkz.webs.com
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DonF »</TD></TR><TR><TD CLASS="quote">The rules require 1 twin barrel carb and certain choke sizes, plus a max displacement. </TD></TR></TABLE>
then that answers my question as to why he was only running 1 carb....
Munkyw3rkz.webs.com
ok i understand now why he was only running 1 carb.... too bad a lot of power would have been had with a pair...
still wanna know if they are running killer cams and if not how are they compensate for the secondary lobe...
What ever happen to XXXXXXX sand rail that he posted on here. It was running on methanol if I remember correctly, didn't the transmission break the first time out? I can't remember his damn name.......
What the hell are emultion tubes??
