just a few smog questions??
Old Oct 10, 2007 | 11:56 AM
Scotland:EF3's Avatar
Default just a few smog questions??
first off ive only lived in cali for two years, but i have to smog again in about a month and i have some questions if you dont mind me asking. first off, this time they sent me "test only" not exactly sure how thats different from just smog check but anyways. On to my 88 ef dx hatch, just swapped from the b2 dx motor to a strong A6 si motor as far as i know everything is running well, replaced timing belt(honda) all fluids(honda), and have been messing with my fuel regulator and idle to get everything just right. Now, i do have an aftermarket exhuast 2 1/4 custom cat back, no resonator, all the way to an es tuning muffler. Will this effect the smog test?? if so, i do have the stock si catback should i swap them before testing? Im just trying to make sure i have everything i need to pass before i go and have this done. Any input is definately helpful, and or places that you HT guys go to for your tests or recommend a place, or recommended changes i can make. Cheers and Beers
Old Oct 10, 2007 | 12:30 PM
anyone?
Old Oct 10, 2007 | 01:39 PM
out there?
Old Oct 10, 2007 | 02:49 PM
Big red89's Avatar
You will probobly have to take it to a referee to get it smogged. They will reguire that everything off the other honda smog wise has to be on your honda. Including cat converter.Call DMV and get the nuber to the referee. They will check out the vehicle and let you know what you need to smog.
Old Oct 11, 2007 | 11:44 AM
i have a ref station at my college and ill will look into it. i still have my cat BTW
Old Oct 11, 2007 | 01:50 PM
jdm_titan's Avatar
Default Re: just a few smog questions?? (Scotland:EF3)
you go to ELAC?? and IMO get the stock look on the exhaust if not u will fail visual and get sent to the REF to the ref!!
Old Oct 11, 2007 | 02:01 PM
MarlonT42's Avatar
Dude...just find someone who can help you "Pass" the car...get my drift. How do you think so many people in Cali "pass" smog with B, and K swaps...
Old Oct 12, 2007 | 11:01 AM
dude i have nothing in my hatch that isnt legit, its a stock si motor, i just want the least amount of probs so i am trying to address them early.
Old Oct 12, 2007 | 11:03 AM
BTw my exhaust does look stock
Old Oct 12, 2007 | 11:45 AM
thesmogman's Avatar
Default Re: (Scotland:EF3)
We do not care what exhaust you have. What we care about is the header and cat.
If you have the stock header/manifold and cat you are in there. If a header it has to have a C.A.R.B. number or you fail. Same with a CAI or SRI.
You do not have to go to a bar ref. That motor did come in the CRX's in 88 so...
No Ref. needed. It is a replacement engine.
Test only is a smog place that does NOT do repairs. The reason for the test only is so you get a good test. Do you feel good about going to a repair shop for the test?
Believe me there has been alot of complaints.
FPR is not needed for a stock motor I would put back on the OEM one and make sure your timing is set to spec.
Good luck!
Old Oct 14, 2007 | 07:39 PM
thanks
wallabee32
Feb 16, 2008 03:48 PM
Dtaandy
Feb 27, 2006 12:54 AM
EKtypeRhaTcH
Mar 9, 2005 07:22 PM
dcvt16
Apr 24, 2004 10:05 AM
Grandma Humper
Jan 9, 2003 01:13 PM
