Clutch Pressure Problem Bleeding Air 93 accord LS
Old Oct 10, 2007 | 10:28 AM
radiuslight's Avatar
Default Clutch Pressure Problem Bleeding Air 93 accord LX
so yea
I Should of done this job on my own from the start
so I had some work done on it
they didnt pinch the lines
so the clutch is now installed and tranny was also put back on
I Tried bleeding the system how it says on the haynes book
but my problem is the pedal has no pressure
it practically goes down on its own when you press it slightly
anyone have an idea??
Modified by radiuslight at 11:55 AM 10/10/2007
Old Oct 10, 2007 | 03:38 PM
Twixle's Avatar
ate my pixel
Default Re: Clutch Pressure Problem Bleeding Air 93 accord LX (radiuslight)
Are you bleeding it correctly? It's much easier with two people. Pump the clutch a few times, have the other person open the bleeder valve, close the bleeder valve, and then let the clutch back out. Repeat until fluid squirts out of the bleeder valve with no air.
Old Oct 10, 2007 | 03:39 PM
Twixle's Avatar
ate my pixel
Default Re: Clutch Pressure Problem Bleeding Air 93 accord LX (Twixle)
Also keep the cap off the fluid resivour and make sure it stays filled while bleeding the line.
Old Oct 10, 2007 | 03:40 PM
Duane_in_Japan's Avatar
You are going to need to vacuum the fluid through and hope the seals arent already damaged.
Old Oct 10, 2007 | 04:04 PM
Default Re: Clutch Pressure Problem Bleeding Air 93 accord LX (Duane_in_Japan)
I think I got it
it made some pressure
but it feels like its not enough
and it wont do any more
Old Oct 10, 2007 | 04:05 PM
vacuum hows that done?
Old Oct 10, 2007 | 10:33 PM
About $150 at NAPA for a vacuum brake bleeder, holds about a half gallon of old fluid.
Old Oct 11, 2007 | 07:57 AM
JimBlake's Avatar
Less than half that for a pressure bleeder, which I think works better.
http://www.motiveproducts.com/02bleeders.html
When I bleed clutches I use it to push new fluid into the clutch slave. That flushes fluid uphill towards the MC, so you're not working against gravity. Air bubbles like to go uphill...
accord478
Nov 20, 2007 01:53 PM
illusion
Jul 31, 2005 09:50 AM
draygenx
Mar 21, 2005 09:21 PM
skierGT
Jul 23, 2003 12:29 PM
PSU-TEG
Dec 3, 2002 08:14 AM
