putting ac back in the rex, only on a d16z6 instead.
Old Jun 19, 2002 | 07:32 PM
xXx Justin xXx's Avatar
Default putting ac back in the rex, only on a d16z6 instead.
i have a 88 dx crx. had ac until i ripped out all of the lines and crap. i was wondering now that i have the 95 civic ex engine in there. does it matter what year and model car i use as far as the ac compressor, ac lines, the ac fan( took mine off and threw it out long ago) and even the lil mini radiator looking thing for the ac infront of the rad. i don't have the compressor for the d16z6, but i do have the 88 dx compressor. or i could get all the lines, fan, compressor, whatever from a different car, like a 89 dx or hf. let me know.too damn hott in the summer to be uncomfortable. thanks
Old Jun 19, 2002 | 08:17 PM
Lt. Dan's Avatar
Default Re: putting ac back in the rex, only on a d16z6 instead. (bstdvtecRx)
all the CRX stuff SHOULD fit.... the only part I see being a problem is the mounting bracket for the compressor...
Dan
Old Jun 20, 2002 | 06:51 PM
Default Re: putting ac back in the rex, only on a d16z6 instead. (Lt. Dan)
so does that mean that i have to use the civic ex compressor? or the bracket or what. i would really like to know what i need to do this before i go getting the wrong parts and jumping into this project, also i am going to the beach in acouple weeks, so i need this done soon!!! thanks for the help.
Old Jun 20, 2002 | 07:08 PM
USDM 4G VTEC's Avatar
u should use all the stock CRX ****
i think u might have to use a CRX bracket to use a CRX compressor
but all the lines should be same **** as the old engine...
Old Jun 20, 2002 | 07:11 PM
Default Re: putting ac back in the rex, only on a d16z6 instead. (JDM EF9)
ok, well as long as i can use the crx compressor with the bracket and lines, everything works and mounts up right. what about the ac belt, are the crx and the d16z6 belt ribs the same? thanks guys..
Old Jun 20, 2002 | 07:23 PM
they are not the same, but the AC compressor adjusts, to make it tight. like an alternator..... if i were u ill go get the stock CRX belt.... see if it works.. if its too short, get a 1 inch larger one and say that the one doesnt work....
peace
Davidss
Jul 16, 2009 05:51 AM
kuki22
May 23, 2007 06:09 PM
frknlo87
May 22, 2005 11:19 PM
