2000 civic si rear shock/ coil assembly
i disassembled by rear shoc/ coil assembly sand cleaned up the bumpber stop n mounting rubber which is fine, but the mount base (piece at top with studs) is oblong, but the holes for the studs and the bushing hol is not warped. the coil fits in it fine, shud i replce it or will that mounting base be ok to reuse?
qfast817
Dec 27, 2006 06:30 PM
