skunk2 springs on a 96 ek
i have sways all around and my ride is to low (i think 3in drop ) cuz it rides like crap im intersted in skunk2 sprins but what kind of shocks should i use KYB or tokico blues hit me up
You should post this in the suspension forums. Better response there for your concern.
I think your drop might be too low and causing it to ride bouncy and feel like crap. I have an EK as well with 205/45/16 rims and I'm only dropped about 1.5 inches all the way around. I am running kyb shocks and skunk2 coil overs with ex front sway and asr rear sway. My ride isn't harsh nor bouncy. I like my setup, perfect for street.
Run the Skunk2 Sport Shocks...
Here is a picture that JHP took of the combo
Here is a picture I took of our Sport Shocks Vs. OEM Vs. Other Aftermarket Brand
Skunk2 Sport Shocks are True Short Body/ Short Stroke Performance Shocks
i bought the skunk2 sport shocks and lowering spring combo off JHP and paired them with some red BLOX lca's. i like the setup but really wouldnt recomend the blox lca's, the hard rubber bushings suck. but anyways skunk2 springs will give you 2.5 in the front and 2.25 in the rear. my buddy with his EK has them on tokico blues, but wouldnt recommend the blues unless you want a softer ride. Go with the Skunk2 sport shocks w/ the skunk2 springs because the those shocks perform better because they are designed for the skunk2's spring rates.
MidwestSi
Suspension & Brakes
Apr 11, 2009 12:20 PM
ImageInMotion.com
67
Dec 11, 2007 06:55 AM
