something is draining my battery
Old Oct 9, 2007 | 08:07 PM
Ruben19's Avatar
Default something is draining my battery
this only happens when the weather is cold.
during the summer i can live the car parked in my garage for weeks and it will start right away.
but when fall, winter i have to recharge the battery within 2 days.
i never set the alarm on and the car has a autolite battery.
could it be the quality of battery and cold cranking amps
Old Oct 10, 2007 | 08:49 AM
slomofo's Avatar
GDD Member
Check to make sure battery connections are good. (Check power wire carefully)
Remove all fuses in your fuse box, then measure battery voltage.
Put one fuse in, then after a few minutes, measure battery voltage. If voltage is significantly lower, you have a problem in that circuit. If not, then continue on to the next fuse and repeat until all fuses are back in.
toner297
Honda Civic (2001 - 2005)
12
May 24, 2011 12:39 AM
braypunt
22
Sep 11, 2005 09:10 AM
DiSbaDbOi
16
Jan 5, 2005 07:24 PM
barefootbilly
14
May 25, 2004 06:32 AM
