good setup for H23 vtec?
Old Oct 9, 2007 | 01:21 PM
Chewy[Ek]'s Avatar
Default good setup for H23 vtec?
"h23 block with jdm f20B head(type S head supposely) with JDM H22 Piston for higher compression. New ACL bearing and ring, mircopolish crank. hone, resurface."
a shop is selling this motor. im thinking about it but i don't know if this is a good setup or not. what do you guys think?
Old Oct 9, 2007 | 01:58 PM
preludefien
Guest
Posts: n/a
Default Re: good setup for H23 vtec? (Chewy[Ek])
go all motor like me if i can ever get a damn block
Old Oct 9, 2007 | 08:21 PM
Chewy[Ek]'s Avatar
Default Re: good setup for H23 vtec? (preludefien)
but is this a good setup? and how reliable is the h23 vtec??
Old Oct 9, 2007 | 08:27 PM
preludefien
Guest
Posts: n/a
i just saw that you have a f20b head. ive never heard of it bolting to a h23 block but thats not to say it cant or hasnt been done. its reliable...i would get a tune just to be on the safe side. me on the other hand im going with high compression pistons and built head. heres my build
https://honda-tech.com/zerothread?id=2110571
should have it dropped in this weekend and off to dyno monday. post results up then
Old Oct 9, 2007 | 09:02 PM
Hawkze_2.3's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chewy[Ek &raquo;</TD></TR><TR><TD CLASS="quote">]but is this a good setup? and how reliable is the h23 vtec??</TD></TR></TABLE>
It's just as reliable as the person who built it. Sounds like a decent setup if it was done right.
Old Oct 10, 2007 | 09:12 PM
Chewy[Ek]'s Avatar
if you had a choice between h23 vtec long block and euro-r long block. which one would you get??
Old Oct 10, 2007 | 09:17 PM
mgags7's Avatar
h23vtec all the way. Get a euro-r IM and some type s cams and you'll be baaaallllllinnnn lol
the H23vtec is reliable as long as it is built well.
the f20b head is the same as the h22.
Old Oct 10, 2007 | 09:43 PM
alterdcreations's Avatar
Default Re: (mgags7)
f20b has smaller valves
Old Oct 10, 2007 | 10:13 PM
94Vtecluder's Avatar
Default Re: (alterdcreations)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mgags7 &raquo;</TD></TR><TR><TD CLASS="quote">
the f20b head is the same as the h22.</TD></TR></TABLE>
Same head just cast differently.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alterdcreations &raquo;</TD></TR><TR><TD CLASS="quote">f20b has smaller valves</TD></TR></TABLE>
I've never heard that. Why would the valves be different?
Old Oct 10, 2007 | 10:39 PM
vinuneuro's Avatar
Default Re: (94Vtecluder)
Smaller bore.
Old Oct 11, 2007 | 03:24 AM
mgags7's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94Vtecluder &raquo;</TD></TR><TR><TD CLASS="quote">I've never heard that. Why would the valves be different?</TD></TR></TABLE>
He's right, they're b series size. The f20b is 85x88. Smaller valves for a smaller engine.
Have the f20b head ported, oversize the valves to h22 size. The valve angles, runners, and ports are exactly the same otherwise.
Old Oct 11, 2007 | 07:08 AM
NirVTEC's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mgags7 &raquo;</TD></TR><TR><TD CLASS="quote">h23vtec all the way. Get a euro-r IM and some type s cams and .</TD></TR></TABLE>
TypeS Cams
Find some used S2S1's.....
xtjentx
May 17, 2007 05:15 AM
rkonfire
May 18, 2004 09:33 AM
Sam1am26
Mar 22, 2004 09:11 AM
stinger
Oct 2, 2003 01:02 PM
shyboy_02
Sep 28, 2003 09:12 PM
