1993 honda del sol
Its that time, just got it done and now i am selling it. $2250 OBO!!
the car developed a knock, its most like likely a valve need to sell to pay for college
Will trade for a DA or some kind of fo' do'
Perfect for LS/VTEC or Boost
Engine:
B18a1
OBD1 running Obd0 injectors with resistor box
New Water pump
T-belt
Head Gasket
Rear main
Crank seal
ARP head studs
EGR block-off plate
PR4 Ecu no CELs
Trans:
94+ Gsr trans w/ 6 puck clutch
Brand new axles
Suspension:
Tokiko Advanced Suspension kit (blue)
Exhaust:
2 1/4 all the way from the header
stainless axleback with mild steel mid everything else
no cat on it but will install one or include it (choice)
Brakes:
Stock, need new pads ( 4 fresh blank rotors included front and rear)
Exterior:
small patch of rust, see pic.
Yellow AUX fog lights
Has an OEM wing (not Pictured)
Interior:
9.2/10
tiny rip on the side bolster of the driver seat
Clean carpet
1993 Driver side air bag only
Pics:
Modified by highrev1987 at 2:17 AM 8/29/2007
Engine:
B18a1
New Water pump
T-belt
Head Gasket
Rear main
Crank seal
ARP head studs
EGR block-off plate
PR4 Ecu no CELs
Trans:
Brand new axles
Suspension:
Exhaust:
Brakes:
Exterior:
Interior:
9.2/10
Clean carpet
Pics:
Johnny race car intercooler
DSM bluetop 450s
t3 garret no shaft play
turbonetics delta gate (needs a spring)
ebay Wastegate works perfect
ebay bov works perfect
po6 ecu
p28 chipped for turbo
the car is wired for vtec
the car has all 4 sony explod speakers
alpine headunit
ARP extended wheel studs still in the box
Apexi timer
some more ecus
a low mileage ls head
the head that i just took off the car was old and shitty but you can have that too
my friend has an ls complete for extra 350 if you want it
i just got a camera so pics will be up tonight
DSM bluetop 450s
po6 ecu
alpine headunit
Apexi timer
some more ecus
highrev1987
Northeast (Sales)
18
Sep 4, 2007 01:01 AM
highrev1987
Sep 3, 2007 06:36 PM
