91 CRX Si GSR swap - Hoses needed?
I'm sorry if this has been posted before but I am failing at finding it in a search query.
I'm keeping my stock CRX Radiator.
I've found many sources on the internet that are all using different hoses
as such:
-94 GSR upper radiator hose trim to fit
-90 integra lower radiator hose trim to fit
CRX front heater hose <- I only know of upper and lower. I can't seem to find one labeled "front"
Any help is greatly appreciated.
Thanks!
as such:
Thanks!
i use a 90 integra upper and lower and trimmed it. you must used the stock crx radiator hoses as a shim to ensure a nice tight seal. intially bought a 95 gsr upper one but it fit weird and their is a kink in using that one. The 90 integra one fit alot better and just needed trimming.
http://www.norcalcrx.org/droppedcrxsi/B16a.htm Has the part number and year you need to use stock crx radiator
heater core hoses, i believe the bottom one i just used my stock crx. the top one that goes to the waterpipe along the back of the block was from hose i bought at autozone cut to fit. They are both the same size in diameter i believe. For me, i used the stock gsr intake manifold and things were a tight fit, but i managed to get things to work. if you use a skunk2, it should be alot easier.
QUiKSR20
Nov 29, 2004 05:45 PM
kizner
Mar 8, 2002 06:04 PM
