obd0?
i was 99% sure that my engine is an obd0 but i have had problems plugging things in and now a buddy has questioned that this engine is even an obd0. can i get some help the head is marked pr3-2 hm and the block is marked b16A 1403164 hm.
Check which ECU you have, that's the easiest way.
You can make any engine/head run any OBD you want if you change some parts. I have a block that was originally OBD-0 (D16A6) and a head that was OBD2 (D16Y8) and it's running OBD1
