What fitting do i need
Old Oct 9, 2007 | 09:17 AM
DarkBB4's Avatar
Default What fitting do i need
I'm trying to hook up my nitrous pressure gauge, and I'm missing the "zex" fitting for it... I went to home depot and came home with a fitting that is ALMOST exactly what i need... I got this fitting, and Now i need to find dimensions for a fitting that will convert the male end to a female to allow this fitting to attatch to the bottle
Old Oct 9, 2007 | 10:22 AM
paulzy's Avatar
you need some 1/8" npt to 3an adapter fittings.
I think the n20 gauge should be 1/8npt fitting as well.
Old Oct 9, 2007 | 11:20 AM
FastCougar's Avatar
Default Re: (paulzy)
NPT & MIP "flares" are 45 degrees, whereas AN & JIC "flares" are 37 degrees. You can't mix & match because you will get a leak!
Old Oct 9, 2007 | 12:47 PM
DarkBB4's Avatar
Default Re: (FastCougar)
ohhh so even though it might seem like their "on right", its not a good seal?
anyone link me to the part i need, id appreciate it!
Old Oct 9, 2007 | 06:18 PM
paulzy's Avatar
this is what you need
http://store.summitracing.com/...22131
and this
http://store.summitracing.com/...w=sku
instructions:
http://static.summitracing.com...1.pdf
jamal-188
May 26, 2003 08:27 AM
CRX Lee
Feb 18, 2003 06:50 PM
BorderM3
Jan 29, 2003 02:11 PM
senpai
Aug 5, 2002 02:20 PM
Mikey3000
May 2, 2002 11:04 AM
