Valve cover gasket weeping
Old Oct 9, 2007 | 04:01 AM
shortlid's Avatar
Default Valve cover gasket weeping
Well about 30,000 miles ago the Previous owner had a shop replace the valve cover gasket on the '99 EX sedan 4 cyl. I bought. Well it is weeping oil again. The bolts that tighten it down areas tight as can be. Just the front weeps not the rear?? Should I try lossening the rear and tightning the front or just replace it again?
Old Oct 9, 2007 | 11:32 AM
Honda-Master's Avatar
Default Re: Valve cover gasket weeping (shortlid)
replace the gasket,, use a honda factory gasket
Old Oct 9, 2007 | 12:37 PM
shortlid's Avatar
Default Re: Valve cover gasket weeping (Honda-Master)
OK, I wonder if teh PO mech. used a cheap knock off?? Prob. did
Old Oct 9, 2007 | 12:58 PM
pos_cd5's Avatar
like stated above, just throw a new gasket on it. the its not hard to do the job, prob take about 20 minutes. make sure to use some RTV silicone sealant. as far as using a OEM honda, even though i did myself, i dont think theres a big difference betweent hat then what you can get at a local aprts store, its just a rubber gasket, and theres not that much pressure in the valve cover.
Old Oct 9, 2007 | 01:02 PM
Duane_in_Japan's Avatar
Get the full kit, gasket, rubber washers under the bolt heads and spark plug seals, keep your spark plug well seals for a friend later if they are still flexable, they should be.
Do not over torque putting it back together, the 10mm studs / bolts break easily. I like to go around the whole thing like three times snugging it down a little more each time. Some guys add some RTV to the four sharp corners (DOHC) at the far ends of each cam hump.
Old Mar 9, 2008 | 10:54 PM
tomatocity's Avatar
Default Re: Valve cover gasket weeping (Duane_in_Japan)
Duane thanks for the information. Does this information also go for a 1993 Accord EX? I just bought a '93 EX with 128,500 miles. It is in pressty good condition. The engine was detailed though today I noticed the front corners of the VC was weeping. The VC bolts were tight.
ps - I was stationed at Tachikawa in 1970-71. Left there and went to Yokota for the remainder. I loved Tachikawa, the surrounding area and day trips to Tokyo. I bet it is different now. I also spent time (14 months) in Northern Okinawa and Kagoshima. Absolutely beautiful.
Old Mar 10, 2008 | 03:38 AM
TouringAccord's Avatar
H-T Order of Merit
Default Re: Valve cover gasket weeping (tomatocity)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tomatocity &raquo;</TD></TR><TR><TD CLASS="quote">Duane thanks for the information. Does this information also go for a 1993 Accord EX? I just bought a '93 EX with 128,500 miles. It is in pressty good condition. The engine was detailed though today I noticed the front corners of the VC was weeping. The VC bolts were tight.</TD></TR></TABLE>
yes... just purchase the gasket kit from the dealer and it will come with everything. Do not over tighten the nuts/bolts holding the valve cover as they can snap rather easy. IIRC 7 lb/ft is the torque spec.
Squigget
Feb 8, 2020 07:12 PM
FinzWake
Nov 23, 2015 07:55 PM
specbb6
Dec 15, 2011 11:21 PM
miksew
13
Oct 20, 2006 05:48 PM
darkfx
Oct 8, 2005 09:51 AM
