Suspension & Brakes Theory, alignment, spring rates....
I need tips.
Old Oct 9, 2007 | 01:01 AM
97delsolryder's Avatar
Default I need tips.
i have a 97 del sol. nothing fancy, but i am considering lowering it. i not looking at goin crazy and dropping it 5 inches but a moderate drop would be fine. i was thinkin between inch and a half to maybe three inches as most.
i have been looking at the kits but i havent noticed any that have any steering linkage accomidations. i want it to sit lower but keep alignment angles within stock settings. what kits are available and what problems might i have?
as always anything helps...thanks
Old Oct 9, 2007 | 04:00 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Are you referring to a lowered car having more of a tendency to bump steer because the outer tie rods angle upwards when the car is lowered? If you're only moderately lowering your car, you'll be fine. Civic and Integra chassis don't have too much of a problem with bump steer. It's the newer Civic Si and RSX's w/ Mac struts up front that have a tendency for nasty bump steer when they're lowered a considerable amount.
Old Oct 9, 2007 | 04:19 PM
b18LS's Avatar
Default Re: I need tips. (97delsolryder)
look into ITR springs. they lower your chassis nicely and are cheap to buy. Roughly 1"
Old Oct 10, 2007 | 06:37 AM
Default Re: (PatrickGSR94)
i must admit, i only have a general idea of what i am doing. i know a lot except what i am doing, when it comes to transmissions and suspension.
but, yeah i am concerned about bump steer and the ball joints, as i just replaced them and i dont want to do it again. one pain in the *** and two its expensive. i was also wondering about camber kits. would it be a good idea to get them, considering i am thinking of lowering it, which would give negative camber.
Old Oct 10, 2007 | 09:06 AM
Community Builder
Default Re: (97delsolryder)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97delsolryder &raquo;</TD></TR><TR><TD CLASS="quote">i must admit, i only have a general idea of what i am doing. i know a lot except what i am doing, when it comes to transmissions and suspension.
but, yeah i am concerned about bump steer and the ball joints, as i just replaced them and i dont want to do it again. one pain in the *** and two its expensive. i was also wondering about camber kits. would it be a good idea to get them, considering i am thinking of lowering it, which would give negative camber.</TD></TR></TABLE>
Some negative camber will help improve handling, and if the car is aligned correctly then a camber kit is not needed. Toe is what wears tires most of the time, not negative camber.
But yeah I've been lowered 6 years and haven't had any problems with steering tie rods. I replaced my original ones less than 2 years ago when the car have over 200K miles on it. I have almost 260K miles now and my current tie rods are just fine.
Old Oct 11, 2007 | 02:38 AM
cool that helps a lot. thanks
thecruzs2007@yahoo.com
Feb 27, 2010 12:56 PM
typac69
Nov 29, 2009 09:46 AM
power11
Suspension & Brakes
Aug 8, 2007 12:44 PM
turnsignalandy
Apr 28, 2007 11:20 AM
hondaracing1
Mar 28, 2005 09:32 AM
