injectors not firing?
Old Oct 8, 2007 | 08:50 PM
90dxb20's Avatar
Default injectors not firing?
ok what i got is a 90 dx crx. i installed a b16 in it a while ago and coverted the harness from dpfi to mpfi myself. the motor ran fine and i eventually broke a rod and i just bought a b20z engine for it. i installed it and tried to crank it and would not fire. ii found out that its gettin fire and Not GETTIN FUEL. ive got fuel pressure but the injectors are not firing. any info at all would be VERY APPRECIATED!!!
Old Oct 8, 2007 | 09:15 PM
KURUPTinc's Avatar
Default Re: injectors not firing? (90dxb20)
what kind of injectors are they peak and hold or saturated? you can manually pull them out and crank the motor and check if they are firing. check all your grounds. Did you convert it yourself? make sure you got the right dizzy
Old Oct 8, 2007 | 09:16 PM
uptownspeedstar's Avatar
check the yellow/black going from the resistor box to the ecu
Old Oct 8, 2007 | 09:26 PM
90dxb20's Avatar
i have the stock b16 injecots in it. i also i have a 91 ls dizzy in it. its getting fire but the injectors are not opening up and spraying into the engine. what pin on the ecu does the yellow and black from the resistor box go to?
Old Oct 8, 2007 | 09:28 PM
90dxb20's Avatar
yes i converted it myself but it ran fine with the b16 but a rod broke and the car has sat like 8 months.
Old Oct 8, 2007 | 09:29 PM
90dxb20's Avatar
how many grounds should there be? i have the 2 on the water neck and i hat goes from the fram rail to the trans to the negative side on the battery.
Old Mar 28, 2009 | 04:53 PM
FSTVTEC's Avatar
any luck??
90dxb20
20
Apr 1, 2009 08:33 PM
sohcEKturbo
Feb 17, 2009 06:39 PM
646EG
Jan 22, 2008 05:12 PM
toeknee360*
Sep 26, 2005 10:09 PM
1RMDave
Jul 22, 2004 08:00 PM
