LS vs GSR in a Ej8 for ME input appreciated
Old Oct 8, 2007 | 08:44 PM
undftdLS's Avatar
Default LS vs GSR in a Ej8 for ME input appreciated
I've been commin to honda tech for a few years now most of my questions get answered before I have to ask because you guys know your ****. I've been lookin to buy a ej8 since I've never had one. I've had everything from a dc to an eg but nothing more than intake and exhaust.. I make good money now and just sold me ek hatch and am looking to swap something in RELIABLE that I won't have to build or repair often.. I'm cool with rebuilding but not right away.
I want to eventually boost. what I want is simple.. 96-00 ex si frnt HIDs full suspension camber kits strut/arm bars ect. dumped on some blades or some emotions gsr black leather interior with a good power plant. I know LS motors are pretty easy to find and cheap. But A Gizzer swap is so solid ya know is it worth the extra money? My goal is to be in the low 13's (not sure what hp goal that is .. 350ish?) and yes this is going to be a daily driver.
Which way should I lean.. Gsr or ls with intentions of boost... will saving the money be worth the wait... btw I got a solid 800 a month to save/spend.
Thank you all for readin and takin the time.
Old Oct 8, 2007 | 08:51 PM
95ProjectEJ1's Avatar
Default Re: LS vs GSR in a Ej8 for ME input appreciated (undftdLS)
Boost the LS and hit 250whp... that should be good for 13's and the money you save you can put towards some aftermarket rods/pistons.
Old Oct 8, 2007 | 09:00 PM
confucioussae's Avatar
Default Re: LS vs GSR in a Ej8 for ME input appreciated (95ProjectEJ1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95ProjectEJ1 &raquo;</TD></TR><TR><TD CLASS="quote">Boost the LS and hit 250whp... that should be good for 13's and the money you save you can put towards some aftermarket rods/pistons. </TD></TR></TABLE>
x2. You'll be much happier with the boosted LS in the long run, and you'll spend less on the LS swap as well.
Old Oct 8, 2007 | 09:37 PM
undftdLS's Avatar
Default Re: LS vs GSR in a Ej8 for ME input appreciated (confucioussae)
is my best bet to find a motor on craigslist or is there any legit sights anyone can recommend? I know buying an engine is always a gambol but what's best?
And how safe is it to boost on a stock block with decent milage? Like 8 psi nothing crazy. Btw thanks again
Old Oct 8, 2007 | 10:36 PM
dohcteg's Avatar
http://www.hmotorsonline.com/ is your best bet. Good motors with warranty.
I know nothing of boost so cant help you there.
Old Oct 8, 2007 | 10:53 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by undftdLS &raquo;</TD></TR><TR><TD CLASS="quote">is my best bet to find a motor on craigslist or is there any legit sights anyone can recommend? I know buying an engine is always a gambol but what's best?
And how safe is it to boost on a stock block with decent milage? Like 8 psi nothing crazy. Btw thanks again</TD></TR></TABLE>
Just make sure your motor is healthy before you do anything do it. Run a compression t and leakdown test, and its also a good idea to tune up just to make sure everything is up to par before you start messing with it. If you don't know what/how do to these tests, you shouldn't be opening your hood.
It is safe, you'll be hitting 13's for sure. there is a thread somewhere in forced induction for LS-T set ups, but i need to do my homework instead of procrastinating on honda-tech. Those guys will be a huge help to you. If you're buying a used motor, make sure you're able to test drive it IN THE CAR to very it's healthy, some of these guys are really shady, and will sell stupid cheap to make a quick buck off fucked up parts and naiive buyers. I've heard nothing but good things from Hmotors ... you could always hit up the JYARD and look for a stock looking teg, and take a gamble.
good luck
Dr3w2k5
Apr 21, 2006 04:06 PM
hatchman12
Jan 7, 2004 07:00 AM
Mefain
May 17, 2003 08:58 AM
PSU-TEG
May 17, 2002 08:13 AM
PSU-TEG
May 13, 2002 10:25 AM
