did my MPFI swap got code 9 & 15 could i have burned up my ignitor?
Old Oct 8, 2007 | 07:20 PM
mattcivic's Avatar
Default did my MPFI swap got code 9 & 15 could i have burned up my ignitor?
well i did my mpfi swap and got codes 9 and 15. so i switched the 2 wires i added to make the mpfi dizzy work and sure enough the codes went away. anywho now im throwing no codes at all but the car has no spark. has anyone else done this and has it burned up your ignitor? i ran out of time tonight on the car and i didnt have my spare ignitor with me so i couldnt see for myself. me and my buddy double and triple checked my wiring and found nothing wrong so this is my best guess.
Old Oct 8, 2007 | 07:22 PM
alscrx's Avatar
Default Re: did my MPFI swap got code 9 & 15 could i have burned up my ignitor? (mattcivic)
Check your ignitor for sure, If not your coil!!
Old Oct 8, 2007 | 07:37 PM
mattcivic's Avatar
Default Re: did my MPFI swap got code 9 & 15 could i have burned up my ignitor? (alscrx)
thats my other theory but i have a hunch it is the ignitor. i guess i realy didnt need to make a post about this im just hoping that someone else has had a similar prob so that i feel like theres a glint of hope that it will fire up when i change it.
Old Oct 8, 2007 | 07:53 PM
alscrx's Avatar
How old is your dizzy?? You may want to get a new dizzy with all new sensors in it, comes with ignitor and coil.
Old Oct 8, 2007 | 09:22 PM
mattcivic's Avatar
i got it from a buddy about a year ago its an OEM dizzy and ive been running it in my wagon up until about a month ago when i took all my go fast goodies from it for my 4wd CRX project. its my first mpfi swap i didnt expect to get it 100% perfect the first time.
Old Oct 8, 2007 | 10:11 PM
dougshatch's Avatar
-----CEL # List-----
1 O2A - Oxygen sensor #1
2 O2B - Oxygen sensor #2
3 MAP - manifold absolute pressure sensor
4 CKP - crank position sensor
5 MAP - manifold absolute pressure sensor
6 ECT - water temperature sensor
7 TPS - throttle position sensor
8 TDC - top dead centre sensor
9 CYP - cylinder sensor
10 IAT - intake air temperature sensor
12 EGR - exhaust gas recirculation lift valve
13 BARO - atmospheric pressure sensor
14 IAC (EACV) - idle air control valve
15 Ignition output signal
16 Fuel injectors
17 VSS - speed sensor
19 Automatic transmission lockup control valve
20 Electrical load detector
21 VTEC spool solenoid valve
22 VTEC pressure valve
23 Knock sensor
30 Automatic transmission A signal
31 Automatic transmission B signal
36 traction control found on JDM ecu's
41 Primary oxygen sensor heater
43 Fuel supply system
45 Fuel system too rich or lean
48 LAF - lean air fuel sensor
54 CKF - crank fluctuation sensor
58 TDC sensor #2
61 Primary oxygen sensor
63 Secondary oxygen sensor circuit
65 Secondary oxygen sensor heater wire (black wires)
67 Cat Converter
71 random misfire cylinder 1
72 random misfire cylinder 2
73 random misfire cylinder 3
74 random misfire cylinder 4
80 EGR Valve/Line
86 ECT sensor - Cooling System
91 Fuel Tank pressure sensor
92 EVAP Solenoid/Valve/Vacuum Lines
i had problem with 15 code somehow it stopped throwing that code all thing i was changed the throwing 10 code and the 15 code is gone but right now im having 17 TSS Speed Sensor
Old Oct 9, 2007 | 06:06 AM
mattcivic's Avatar
Default Re: did my MPFI swap got code 9 & 15 could i have burned up my ignitor? (dougshatch)
i knew what codes they were but thanx. hhmm iono ill find out today if it works or not.
nitewolf
12
Aug 21, 2009 10:08 AM
cjwarren4dcivic
14
May 1, 2006 11:25 AM
91' LS-VTEC
13
Jan 12, 2006 08:25 PM
Red_Si
21
Jan 9, 2004 04:53 AM
TurboEF9
14
Jan 13, 2003 02:20 PM
