b18a1 into ef question
hello ef owners, i have a 1992 acura integra with a b18a1 its all pritty much stock and i want to put it into my 91 ef hatch, do i need anything else besides engine mounts and a shift linkage to make the swap work? Can i use the engine harness, axels, and the ecu from the integra?
use the pr4 with the engine harness and da axles remember to remove the hub dust seals for the axles to fit properly and the linkage will not bolt on up. Have to cut like 2in or so for proper fit. And are mounts decent shape. Good luck.
Ef9_408
Dec 30, 2017 04:01 PM
