my type r is going ZOMBIE ON ME!!!
Old Oct 8, 2007 | 04:05 PM
integra_type-r's Avatar
Default my type r is going ZOMBIE ON ME!!!
what the expletive is going on?
CEL code 90 p1457 has been on going for 3 years now << tried everything i could to fix
front was fucked, but converted to the jdm front <<- remember my old thread my yellow r with the silver jdm front? (fast conversion?)
car is all primered white now don't know when its gonna get painted due to transportation cuzz my sisters R got stolen
car run between LEAN and Storch on my airfuel ratio
NOW my back bumper is all black from **** coming out from my exhaust don't even know why its doing that now
@ about 94.000 miles now, please list some parts of what i should replace
thanks
Old Oct 8, 2007 | 05:11 PM
rhdc2itr's Avatar
Default Re: my type r is going ZOMBIE ON ME!!! (integra_type-r)
sounds like your exhaust is to close to bumper and your cat is going out. the same thing happen to me when my cat went out bunch of black heavy smoke came out.
Old Oct 8, 2007 | 05:23 PM
4F_RiverOtter's Avatar
Default Re: my type r is going ZOMBIE ON ME!!! (rhdc2itr)
What did you do to try and fix it? The front end damage could have messed up the wiring. P1457 is your EVAP system. Check all wires running to the canister. Check the evap control canister shut valve. Also, check the evap purge control solenoid valve. Also, check the vacuum lines to the canister/valves. If there are no shorts in the wires and you test the valves and they work...you could try a known good ECU.
Old Oct 9, 2007 | 12:48 PM
mart182003's Avatar
i have a question for you do you know what bulb size does the low beam use on the jdm type r.
Old Oct 9, 2007 | 12:49 PM
jgirard's Avatar
Default Re: my type r is going ZOMBIE ON ME!!! (mart182003)
I believe its 9006
Old Oct 9, 2007 | 01:15 PM
coolhandluke's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mart182003 &raquo;</TD></TR><TR><TD CLASS="quote">i have a question for you do you know what bulb size does the low beam use on the jdm type r.</TD></TR></TABLE>
Check this link here
B16EJ
Jun 20, 2016 03:53 PM
ericlee303
Mar 23, 2008 07:30 AM
b00sted4dr
Mar 3, 2004 11:49 AM
pRosmAt3c
Sep 7, 2003 01:27 AM
E Swift
Jul 27, 2003 01:57 PM
