82 mm pistons on stock sleeve, any issues? (search done)
I made a lot of search and found nothing about using 82 mm pistons in B18c engine
Some people had problems with this big bore on stock sleeves?
thanks for your help
Naw, its probably the most you would ever want to go on stock GSR sleeves, especially if you're running high CR or spray, even worse if you Boost. I plan on going 82 on my next build, im at 81.5mm right now on one of my blocks.
fastludeh22
Aug 12, 2002 07:36 AM
