Engine motor swap '01 Prelude SH to '99 Prelude base
Old Oct 8, 2007 | 01:50 PM
siguana's Avatar
Default Engine motor swap '01 Prelude SH to '99 Prelude base
Need advise. I found a used motor for my 99 prelude base. it's a 01 prelude sh and i was wondering if any major modification or mounting adjustment is invovled. also, i currently have a supercharger by jackson installed that smoked my engine. Should i keep it or take it out during the swap?
Old Oct 8, 2007 | 02:23 PM
NirVTEC's Avatar
Default Re: Engine motor swap '01 Prelude SH to '99 Prelude base (siguana)
What exactly is wrong with your engine?
Youre better off finding a Base US H22 or a JDM H22. You will need to make some changes for the SH motor and I don't think your trans will work without changes.
Old Oct 8, 2007 | 02:25 PM
vinuneuro's Avatar
pm PirateMcfred for an adapter plate ($75) so that you can use your existing transmission and axles. Other than that it's a straightforward swap. You shouldn't have any issues with your supercharger as long as you get it properly tuned.
Old Oct 8, 2007 | 02:42 PM
NirVTEC's Avatar
Default Re: Engine motor swap '01 Prelude SH to '99 Prelude base (vinuneuro)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vinuneuro &raquo;</TD></TR><TR><TD CLASS="quote">pm PirateMcfred for an adapter plate ($75) so that you can use your existing transmission and axles. Other than that it's a straightforward swap. You shouldn't have any issues with your supercharger as long as you get it properly tuned.</TD></TR></TABLE>
It really comes down to how cheap that SH motor can be had for...
Old Oct 8, 2007 | 02:57 PM
vinuneuro's Avatar
Default Re: Engine motor swap '01 Prelude SH to '99 Prelude base (::NirVTEC::)
Doesn't it always? If this is a good deal for him, the fact that it's out of an SH shouldn't stop him since he's only a $75 adapter plate away from running it in his car without any problems.
Old Oct 9, 2007 | 06:07 AM
NirVTEC's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vinuneuro &raquo;</TD></TR><TR><TD CLASS="quote">Doesn't it always? If this is a good deal for him, the fact that it's out of an SH shouldn't stop him since he's only a $75 adapter plate away from running it in his car without any problems.</TD></TR></TABLE>
Any long term testing on this part?
Is the adaptor plate to use a Non SH trans on an SH block or to just get rid of ATTS on an SH block/trans combo? As you know, I don't know much about anything OBD2 or ATTS related.
Old Oct 9, 2007 | 08:27 AM
vinuneuro's Avatar
It's the same thing as an H2B adapter, a very simple concept. It enables the user to use a non-M2U4 trans. There are a few people using the product, and we would've heard if there were any issues. Since this is Pirate's product, I have the utmost confidence it.
Old Oct 9, 2007 | 11:08 AM
siguana's Avatar
thanks for the overwhelming responses. first of all, here is the reason why i need it replaced. i noticed white smoke coming out from the breather. i get it checked at several places and the most common answer i got was that air is leaking thru the piston (due to supercharger and lack of proper tunin) and motor needs to be replaced right away or else.........."fire in the hole!". Secondly i found this motor locally (01' SH) with 22K asking for $12K. That's the best deal i've got so far but i was told that the mounting could be different between the two model. Well guys thanks and keep me posted if you have any crazy ideas,
Old Oct 9, 2007 | 11:46 AM
shrirag's Avatar
Either I'm slow or you just said you are paying 12k for an 01SH MOTOR? Even with 22k, umm you can get the whole car for that price.
Old Oct 9, 2007 | 11:56 AM
vinuneuro's Avatar
Default Re: Engine motor swap '01 Prelude SH to '99 Prelude base (shrirag)
He probably typo'd..
Old Oct 9, 2007 | 01:05 PM
siguana's Avatar
oooops typo it's $1,200
Old Oct 9, 2007 | 01:30 PM
siguana's Avatar
where can i purchase this pm adapter vig?
Old Oct 9, 2007 | 02:50 PM
vinuneuro's Avatar
That's not a very good deal. Call and ask http://www.hmotorsonline.com how much it'd be just for a longblock without the transmission.
Old Oct 9, 2007 | 04:08 PM
siguana's Avatar
my search came to a dead end. hey vig, i called those guy from ur link and they told me it's a major swap. trans is not compatible, att (don't know what the hell that means) unit is different, oil filter is located elsewhere and so one...... they told me to stick with a h22 motor
T.T
Old Oct 10, 2007 | 06:20 AM
NirVTEC's Avatar
What not just get a nice JDM H22 for that price?!
The S/C would love the 10.6:1cr.
do you have to take emissions where you live?
Old Oct 10, 2007 | 07:07 AM
vinuneuro's Avatar
I agree with Nirvtec. You're much better of getting the JDM H22 unless you can get the SH motor much cheaper.
Old Oct 10, 2007 | 10:12 AM
Ralleh's Avatar
Would it be cheaper to just rebuild the current engine?
Old Oct 10, 2007 | 10:22 AM
bb4 jdm lude's Avatar
Default Re: (Ralleh)
the only reall difference in the motors is the transmission which has ATTS(all time traction system) SH(super handling) but yea get a JDM H22
Old Oct 11, 2007 | 06:40 AM
NirVTEC's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ralleh &raquo;</TD></TR><TR><TD CLASS="quote">Would it be cheaper to just rebuild the current engine? </TD></TR></TABLE>
No. Its something I have explored many many times.
You have to remeber you can still sell your old engine. I average about $500 for DEAD H22's on my last 2 excursions.
I don't know what H motors does on shipping but I think I can get an H22 to your door a little cheaper. Too add, I have tons of confidence in them because of the level of abuse they have seen in my cars.
Old Oct 11, 2007 | 02:10 PM
siguana's Avatar
Default Re: (::NirVTEC::)
nirvtec, i live in el paso TX. can you advise me where to start or maybe help in getting one for a good deal?
Old Oct 11, 2007 | 02:25 PM
vinuneuro's Avatar
Default Re: (siguana)
Call hmotorsonline.com and ask them for just a longblock, no trans. Should be ~1200.
Old Oct 11, 2007 | 02:43 PM
arkosh.kovash's Avatar
* B A N N E D *
do you have emissions in El Paso? Just wondering cause it may make a difference in what motor you want to get....
Old Oct 13, 2007 | 11:43 PM
siguana's Avatar
Default Re: (arkosh.kovash)
we do have emission here in tx
accordingdone
Jan 19, 2014 05:40 AM
KleenKrew
Aug 28, 2010 10:37 PM
JDM809
Oct 5, 2009 09:40 AM
munky_350
May 10, 2008 11:01 PM
jusfuknpounum
Mar 31, 2004 07:19 PM
