power window: regulator bolt problem
Old Jun 19, 2002 | 03:42 PM
civicb18b's Avatar
Default power window: regulator bolt problem
check out the pics before reading this:
http://members8.clubphoto.com/mike53...ner-989a.phtml
My window has been closing awkwardly because the regulator bolts have come out of alignment. Not only are they out of alignment, but they have torn up the metal around the bolts (see pic). When I tighten the three bolts down tighter factory specs the window wont close or open without the guidance of me. If the bolts aren’t tight enough, the regulator has play to it thus not allowing the window to shut properly. What can I do? I plan on using washers so the bolts don’t strip any more of the hole away. Does that sound like a good idea? Any input?
[Modified by civicb18b, 12:51 AM 6/20/2002]
Old Jun 19, 2002 | 03:52 PM
VTEC
Guest
Posts: n/a
Default Re: power window: regulator bolt problem (civicb18b)
I just replaced my driver's side regulator on Memorial Day. I'm at work so I can't help out, but I will try to give some advice when I get home today...
crxricer66
Nov 20, 2007 12:42 PM
WhiteOnRice
Mar 8, 2007 03:32 PM
Raf99
Apr 2, 2006 04:50 PM
Devilry
Nov 22, 2004 07:35 PM
jakeiscool
Jul 23, 2004 08:29 PM
