wtt: 1g dsm for a honda
As the title says, I am in the market to trade my 1g dsm for a honda.
Only issue it has is that the fuel pump cuts out for some reason a few seconds ofter the car starts. It is now directly wired, bypassing the fuel pump relay to run. It runs fine. We think that it is the relay or the ecu, I have an extra ecu to go with the car.
Mods:
Rebuilt Engine as of August 06. Done by previous owner, no receipt, dont know exact mileage.
Built Head- Everything but cams.
Newer Trans
255 Fuel Pump
3" apexi Exhaust
External Wastegate
I am looking for a trade for any vtec honda. Let me know what you have. I am located in South Jersey.
The engine pic is old, its from when i first got the car. It now has a filter, recirc pipe, bolts etc.
Modified by 96integrals1505 at 3:01 PM 10/8/2007
Mods:
Newer Trans
255 Fuel Pump
3" apexi Exhaust
External Wastegate
Hey if you interested i have a daily reliable i drive it everyday driver thats in perfect runing condition it runs strong and has a lot donr evrytyhing is basicly new let me know what you think
B18A1 motor with about 10000 miles on the complete rebuildhoned blockcompletely blue printed and balanced bottom end (everything within a gram of itself)Head complete rebuild with Brand new honda replacement everything3 angle Valve jobmilled 40 over (.004)ported and polished head with every port matched to intake and exhaust gaskets.b16 trans with 65K miles Brand new axles shift perfect7 pound flywheel AZ race with 4 puck clutch ClutchMaster.colt camshafts with custom grind & performance cam seals( well not leak) http://www.coltcams.com Adjustable STR cam gearscolt cold air intakeobx 4-2-1 headerobx ehxaust pipingractive mufler2 1/2" exhaust is completely welded all around lowered on adjustable coiloversshort shiftermanual fan, temp controllerStock brand new honda replacement hardened,treated, and polished pistons and rods all balanced & blueprintedrings are Brand new stock honda replacementsJust needs a little more fuel and maybe tunning runs high 13s just how it is bigger,injectors,fuel regulator, tunning nice tires and your in the 12s easy.i drive the car everyday 55 miles one way 110 miles plus a day. i change the oil every month. still gets 28MPG. its a little ugly it needs cosmetics its a sleeper.
Yuta
Oct 12, 2018 07:26 PM
