Tranny help!
Old Oct 8, 2007 | 09:39 AM
90 civic hb's Avatar
Default Tranny help!
Okay i have a 90 civic HB std with a sucky 4 speed manual and i was wondering if a can put a 88-91 hb,crx zc tranny on a D15b1 engine! what parts do i need to make it work! axles,hubs any ideas! what am i missing?
help pleaze
Old Oct 8, 2007 | 09:44 AM
wiZCo's Avatar
Stouts 'n' Scotch
You can put a DX/LX, Si/EX or HF transmission on your vehicle without changing the axles or hubs. Just make sure it's an 89-91. Using an 88 transmission will require an 88 flywheel and clutch.
You could also use the ZC trans, but you'd need to tap the holes on the block to use the intermediate shaft. You also would need new axles with that trans.
Old Oct 8, 2007 | 10:56 AM
jlicrx's Avatar
Default Re: (wiZCo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wiZCo &raquo;</TD></TR><TR><TD CLASS="quote">You could also use the ZC trans, but you'd need to tap the holes on the block to use the intermediate shaft. You also would need new axles with that trans.</TD></TR></TABLE>D15B1 and D15B2 blocks don't have holes that can be tapped - this is D15 block
Old Oct 8, 2007 | 11:04 AM
wiZCo's Avatar
Stouts 'n' Scotch
Default Re: (jlicrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jlicrx &raquo;</TD></TR><TR><TD CLASS="quote">D15B1 and D15B2 blocks don't have holes that can be tapped - this is D15 block
Thank you sir. I didn't catch that it was going on a D15.
hondacivic90zc
Apr 8, 2007 07:54 AM
Tippyman
38
May 16, 2006 04:34 PM
TH33G4MON3
10
Sep 11, 2005 02:30 PM
teewhy55
Sep 6, 2005 12:12 AM
bbrian
Feb 3, 2005 04:48 PM
