Suspension & Brakes Theory, alignment, spring rates....
ITR rear sway into a 2000 Civic Si
Old Oct 8, 2007 | 07:18 AM
blaze the chemi's Avatar
Default ITR rear sway into a 2000 Civic Si
I bought a comptech lower rear tie bar, ITR rear sway with the correct D-brackets and prothane bushings. The only questions I have is the endlink holes on the ITR rear bar. Do I have to buy the bushings and hardware setup for the ITR or could I reuse my Si hardware setup. I know I can reuse the Si endlinks, but I notice that the aftermarket kits always have bushings for the endlink.
My question is do I have to buy parts #46 (aka #8), #11 and #37 or can I reuse my Si hardware. Thanks.
Old Oct 8, 2007 | 10:07 AM
Blk00EJ8's Avatar
Default Re: ITR rear sway into a 2000 Civic Si (blaze the chemi)
I'm pretty sure the Si rear sway doesn't have sleeve #8 or bushing #37. The endlink bolts directly to the bar and then directly to the LCA. So if your new ITR bar has that type of bushing/endlink combo in the pic, then yea you'd have to order them.
Old Oct 8, 2007 | 10:23 AM
siblues's Avatar
Default Re: ITR rear sway into a 2000 Civic Si (Blk00EJ8)
Its been a while since I did mine but I believe the gentleman above is correct.
Old Oct 8, 2007 | 11:42 AM
Default Re: ITR rear sway into a 2000 Civic Si (siblues)
Thanks guys. I'll give the local Acura dealership a call and order them. I just hate buying parts that aren't needed.
Old Oct 8, 2007 | 08:59 PM
Blk00EJ8's Avatar
Dunno if it would make sense to ship the parts, but usually the savings on the parts offsets the cost of shipping in your favor:
Acura Automotive Parts
Honda Automotive Parts
Great for large orders, parts are about 20% off from those of a stealership
Old Oct 11, 2007 | 05:16 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blk00EJ8 &raquo;</TD></TR><TR><TD CLASS="quote">Dunno if it would make sense to ship the parts, but usually the savings on the parts offsets the cost of shipping in your favor:
Great for large orders, parts are about 20% off from those of a stealership </TD></TR></TABLE>
I know of those sites, but since i'm ordering such a low amount of items it saves me money to pick it up. Besides the stealership is on the way home.
Just an update on my progess though:
The endlink bushings (#11) have a hole that is big enough for the OEM Si endlinks to go through, but items #8 (aka #46) are not needed. You have to really push the nut back onto the endlink bolt in order for you to get a good fastening. Also item #7 is too big for aftermarkets sway bar bushings I'm getting 2- #10 (bushings) from the dealership and taking back those unneeded items (#8). I now have two extra prothane 22mm sway bar bushings.
Old Apr 23, 2008 | 04:15 PM
jonshonda's Avatar
Community Builder
My CTR bar will work for you!!
Old Apr 23, 2008 | 06:18 PM
TotalBalance's Avatar
Default Re: (jonshonda)
pics doesnt work, but i believe ITR bar has larger endlink holes than CTR's, meaning your si endlink will be too small for the itr holes.
I believe ASR is selling bushings that goes into the endlink hole of ITR's, so the SI's endlinks fit.
Old Apr 24, 2008 | 11:47 AM
crx(gator)'s Avatar
Default Re: (TotalBalance)
i just ordered the rear sway bar and all the bushings, bolts and endlinks for an ITR as well...this will fit my Em1 correct? i am using an ASR subframe as well...do i need asr bolts to bolt up the d-brackets into the subframe or will oem honda work?
Old Apr 27, 2008 | 10:28 PM
Default Re: (crx(gator))
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crx(gator) &raquo;</TD></TR><TR><TD CLASS="quote">i just ordered the rear sway bar and all the bushings, bolts and endlinks for an ITR as well...this will fit my Em1 correct? i am using an ASR subframe as well...do i need asr bolts to bolt up the d-brackets into the subframe or will oem honda work?</TD></TR></TABLE>
NO. if your car is EM1 (99-00 Civic SI), then you just re-use your stock endlinks from stock sway bar. ITR endlinks WILL NOT work on your car.
Old Apr 28, 2008 | 08:21 AM
crx(gator)'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TotalBalance &raquo;</TD></TR><TR><TD CLASS="quote">
NO. if your car is EM1 (99-00 Civic SI), then you just re-use your stock endlinks from stock sway bar. ITR endlinks WILL NOT work on your car.</TD></TR></TABLE>
are you sure about this because the Si endlink is way different in terms of mounting on the sway bar than the itr one...
Spoon-EK9
Suspension & Brakes
Jan 15, 2006 12:09 PM
JJ-Built
Suspension & Brakes
Nov 3, 2005 01:08 PM
null.
Aug 7, 2004 04:05 PM
2lobes1engine
Apr 21, 2004 10:13 PM
Two_K Si
Aug 21, 2003 06:26 PM
