Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Rev limited to Vtec RPM
Old Oct 8, 2007 | 12:40 AM
fongyz22's Avatar
Default Rev limited to Vtec RPM
Just as the title says....I was driving to the green bay packer game from my school (2.5 hour drive)....CEL on the way there. I didn't think it was serious....everything was fine, gased up before coming back home. THEN; while merging on the highway, from gear one to gear two, the rev limiter seems to kick in at 4100 RPM (my vtec switchover rpm), same goes from gear 2-3...etc...sucks! my mpg also went down from 230 miles for 1/2 tank to 172 miles half a tank. What's up??
Old Oct 8, 2007 | 02:09 AM
thinknology's Avatar
Default Re: Rev limited to Vtec RPM (fongyz22)
When is the last time you changed your transmission oil? Engine oil?
Old Oct 8, 2007 | 03:53 AM
recaroem2's Avatar
Default Re: Rev limited to Vtec RPM (thinknology)
oil or spark plugs, injectors any of those might do it
Old Oct 8, 2007 | 04:24 AM
daddy's Avatar
Default Re: Rev limited to Vtec RPM (recaroem2)
search. your car is going into limp mode becuase it thinks something is going wrong. do an oil change. it'll take care of it
Old Oct 8, 2007 | 06:53 AM
elitezdc5's Avatar
Default Re: Rev limited to Vtec RPM (daddy2be)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by daddy2be &raquo;</TD></TR><TR><TD CLASS="quote">search. your car is going into limp mode becuase it thinks something is going wrong. do an oil change. it'll take care of it</TD></TR></TABLE>
yup ur low on oil. honda puts u can say a safety switch when ur low on oil and the car will only rev to 4k to save the motor instead of people revving to 6500k then they blow a rod. ive had the limp mode thing before.
Old Oct 8, 2007 | 07:54 AM
fongyz22's Avatar
Default Re: Rev limited to Vtec RPM (sspem2)
oh, yeah, i think that could be eat, maybe I'm leaking?? cuz I'm almost 3000K since my last oil change, i'm about 800 miles short lol. Nothing to do with the vtec thingy majiggy? Also, my temp gauge seems to be fine, sits right below half. :X I'll do an oil change. I'll do a change on both trans and engine oil, Thanks for the input guys!
polo609's Avatar
I had something kind of similar, except, at a given point, my car would rev all the way to limiter for a few seconds without me even pressing the pedal! I was freaking out the first time and luckily my foot was on the clutch..it happened a second time a week later so i changed my oil, put that **** that clears the injectors, and so far so good.
Old Oct 8, 2007 | 08:16 AM
daddy's Avatar
Default Re: (polo609)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fongyz22 &raquo;</TD></TR><TR><TD CLASS="quote">oh, yeah, i think that could be eat, maybe I'm leaking?? cuz I'm almost 3000K since my last oil change, i'm about 800 miles short lol. Nothing to do with the vtec thingy majiggy? Also, my temp gauge seems to be fine, sits right below half. :X I'll do an oil change. I'll do a change on both trans and engine oil, Thanks for the input guys!</TD></TR></TABLE>
i hope you mean 3k.
i didnt notice any difference in my temperature when i had the same problem. the only thing i notcied was the oil was dirty. but the oil change has fixed htis both tiems its happpend. the first time it had been almost 5k since the last oil change and the second time it had been 3k. no problems since tho and its been close to 10k and 2 oil changes since it last happend (changing hte oil again this weekend)
Old Oct 8, 2007 | 08:32 AM
toyomatt84's Avatar
Sanji
That, and Vtec kicks in at 2700rpms.
Old Oct 8, 2007 | 08:51 AM
fongyz22's Avatar
Default Re: Rev limited to Vtec RPM (toyomatt84)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by toyomatt84 &raquo;</TD></TR><TR><TD CLASS="quote">
That, and Vtec kicks in at 2700rpms.</TD></TR></TABLE>
hah, okay, I learned something-S today yay for HT!! Will change oil today or tomorrow cuz I'm back on campus and yeah, classes...
Oh and yeah, I did mean 3000 MILES lol not 3000K miles.
Old Oct 8, 2007 | 11:35 AM
Boilermaker1's Avatar
yeah, but even with a VTEC error it'll cut you off at 4K. I've left the solenoid unplugged by accident before.
Regardles... did you ever scan the code? In about 3 seconds you'd know why the car is in safe mode.
Old Oct 9, 2007 | 05:50 AM
fongyz22's Avatar
Default Re: Rev limited to Vtec RPM (Boilermaker1)
Yes, I was DEFINITELY low on oil. Drained it, (drain plug was a b!tch to get out this time around), and it came out to 1/2 quart....LOL...possible leak somewhere? I'm sure there's no burning...
Old Oct 9, 2007 | 06:04 AM
1/2 QUART.... wow.... not good
Check around your engine see if your getting a leak, or on the drive way. Run it at the same time let it get nice and warm then check.
Old Oct 9, 2007 | 07:49 PM
integraa972's Avatar
last time this happened to me i blew up my motor lol
Old Oct 11, 2007 | 07:28 PM
Harlowe's Avatar
Function>Fashion
You're lucky nothing serious happened..
Old Oct 11, 2007 | 07:55 PM
JDMSalvi55's Avatar
Same exact thing happened to my car.... My RPM's wouldn't go past 4k...... V tec wouldn't kick in at all... etc... my car was a mess ...... Sure enough i was low on oil! Had to take my car to get a few seals replaced because it was leaking oil !!! just cuz u cant smell burning oil doesn't mean ur car aint leakin... play it safe, take it to get it checked out and get ur seals replaced if u need them.... will save u from having to buy a new engine!!!! Unless u wana use that excuse to replace ur engine with a K20
Old Oct 12, 2007 | 01:28 AM
01LXCoupe's Avatar
That was a close call. Do all Honda motors have this safe mode?
Old Oct 12, 2007 | 01:46 AM
toyomatt84's Avatar
Sanji
Default Re: (01LXCoupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 01LXCoupe &raquo;</TD></TR><TR><TD CLASS="quote">That was a close call. Do all Honda motors have this safe mode?</TD></TR></TABLE>
If you're referring to 'limp mode', then yes, all 7th gen. Civics have 'limp mode'.
Old Oct 12, 2007 | 04:20 AM
Default Re: (toyomatt84)
If you're referring to 'limp mode', then yes, all 7th gen. Civics have 'limp mode'.</TD></TR></TABLE>
'limp mode' teehee makes me giggle.
But for the future guys, changing your oil on a regular basis 3k-5k I'm not gonna argue all the details for it... that's a whole other thread, and checking it every week or too and looking over your car (aka PREVENTATIVE maintenance) will benefit you greatly in the long run.
mvp97gsr
Nov 29, 2007 07:59 AM
hurleyrob
14
Jun 27, 2006 09:51 PM
soloteg2
Apr 9, 2006 10:58 AM
danacixem
Aug 10, 2004 01:13 PM
yellowbuffalo
May 2, 2002 07:31 PM
