My Blown Motor . In your opinion what do you think happened? [56k chill]
Old Oct 8, 2007 | 12:10 AM
Reza^'s Avatar
Default My Blown Motor . In your opinion what do you think happened? [56k chill]
Any Ideas what could have happened?
I would like to figure out what went wrong to avoid any similar problems with the next build , thanks
Old Oct 8, 2007 | 12:13 AM
mR. Vash's Avatar
Default Re: My Blown Motor . In your opinion what do you think happened? [56k chill] (Reza^)
Holy crap! I don't know what happened, but I'm sorry for your lost
Old Oct 8, 2007 | 12:28 AM
Stefndogg's Avatar
Default Re: My Blown Motor . In your opinion what do you think happened? [56k chill] (mR. Vash)
bearing failure would be my guess..
Old Oct 8, 2007 | 12:37 AM
Scotty Dosent Know's Avatar
Default Re: My Blown Motor . In your opinion what do you think happened? [56k chill] (Stefndogg)
plastigage FTW!
honestly I dont know its hard to tell from your pictures did you drop a valve? break a rod? what happned when it went, did it just go? or did you get rod knock?
Old Oct 8, 2007 | 12:38 AM
777's Avatar
777
holy ****...
MonkeyManStunna's Avatar
Default Re: My Blown Motor . In your opinion what do you think happened? [56k chill] (Scotty Dosent Know)
^ i was going to say the same thing... looks like you dropped a valve, bearings don't look to good either. Damn man when this happen?
Old Oct 8, 2007 | 12:40 AM
drastikchangez's Avatar
Default Re: My Blown Motor . In your opinion what do you think happened? [56k chill] (MonkeyManStunna)
looks like my old gsr motor sorry for your loss bro and good luck on your next build.
Old Oct 8, 2007 | 12:41 AM
5 Speed AP2's Avatar
these are some nice pics for a not so nice scenario.
time for a new build man.
Reza^'s Avatar
it happened at buttonwillow ..
I was in the turn riverside , I would say close to 95 mph at 8500 rpm's and then it went hard..
Rod knock was heard right before that session but it went away after a few seconds , why I didn't leave the car off ? .. I got greedy and wanted to run one more session.
I was running the ctr pulley with a stock oil pump . maybe the ctr pulley strained the oem oil pump and it failed? From what I heard it's better to run the
" toda gear " for the oil pump with the ctr pulley.. ?
Old Oct 8, 2007 | 12:44 AM
Damn well atleast that motor went out with some dignity!
what are you plans for next motor? high comp 2.0l block
Old Oct 8, 2007 | 12:53 AM
alltech.magoo's Avatar
Damn sorry to hear about your motor... G/L on the next build.
Old Oct 8, 2007 | 12:56 AM
Reza^'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MonkeyManStunna &raquo;</TD></TR><TR><TD CLASS="quote">^ i was going to say the same thing... looks like you dropped a valve, bearings don't look to good either. Damn man when this happen?</TD></TR></TABLE>
from a past experience with the valve dropping the motor pretty much fluttered and came to a stop , this time the motor had a loud pop sound and blew out from the bottom. I have the stem of the valve , it' s shaped.
I think the bearings failed or the oil pump.
Old Oct 8, 2007 | 02:04 AM
EJ8 944's Avatar
double post my bad
Old Oct 8, 2007 | 02:05 AM
EJ8 944's Avatar
wheres the dish of the missing valve?
i cringe when i think that that must have sounded like when it blew
Old Oct 8, 2007 | 02:07 AM
EkJavi's Avatar
* B A N N E D *
daaaaaaaamn
Old Oct 8, 2007 | 02:15 AM
permaisuri's Avatar
Default Re: My Blown Motor . In your opinion what do you think happened? [56k chill] (EkJavi)
man!! you've got the same name as me, and we had exactly the same problem!! except my block have a biiiig hole!!! valves broke!! and it happened on cylinder no 2!!!
i dont know what went wrong!!!
well, good luck with the next build!!!
Old Oct 8, 2007 | 03:41 AM
SlobberGoat's Avatar
Default Re: My Blown Motor . In your opinion what do you think happened? [56k chill] (permaisuri)
Even during a disaster your taking silky smooth pics?
Respect!
Old Oct 8, 2007 | 04:13 AM
Boost_V's Avatar
Default Re: My Blown Motor . In your opinion what do you think happened? [56k chill] (SlobberGoat)
Those are the BEST pics of a blown motor i've ever seen!
Old Oct 8, 2007 | 04:58 AM
civhatch90's Avatar
why are you posting pics of your blown motor on a/c?? it seems as if you would get better responses on other sections of the forum
Old Oct 8, 2007 | 05:47 AM
Baggy Spandex's Avatar
Default Re: (civhatch90)
Reza, are you running anything in terms of a baffled oil pan? Could possibly be oil starvation under hard cornering. Im sure you are running one with the experience you have.
Also, is the motor fresh? What was the break-in method? Only reason I ask, is I know that a lot of low-rpm 'lugging' of the motor (low-rpm+full throttle) can squeeze oil from the face of the bearings.
Old Oct 8, 2007 | 06:03 AM
Mrs. Triscuit's Avatar
Around a corner, 8500rpm, oil starvation, over revving with P72 rods= Rod Bolt failure which turned into rod separation.
Old Oct 8, 2007 | 06:06 AM
Default Re: My Blown Motor . In your opinion what do you think happened? [56k chill] (Mrs. Triscuit)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mrs. Triscuit &raquo;</TD></TR><TR><TD CLASS="quote">Around a corner, 8500rpm, oil starvation, over revving with P72 rods= Rod Bolt failure which turned into rod separation.</TD></TR></TABLE>
True Were they ARP bolts? I had ARP rod bolts in my ls/vtec build, and it spun happy up to 8500rpm. Factory LS rods too.
Old Oct 8, 2007 | 06:18 AM
bobbybo213's Avatar
did the cylinder hit a valve?
Old Oct 8, 2007 | 06:23 AM
G'Funk's Avatar
Default Re: My Blown Motor . In your opinion what do you think happened? [56k chill] (Baggy Spandex)
It could be what these guys above said, oil starvation. I know your an avid racer so this situation probably came up quite often, maybe with the repeditevness the bolts finally gave out. But from the pictures I honestly think it is something along the line of a spun bearing. Because if it slipped out at that RPM then holey sh*t a disaster like that could definantley happen. The internals look the same as when my motor spun a bearing, but my rod just bent didnt snap like yours. The only thing I can think of is to either a) get some arp rod bolts for the next build, or b) get some aftermarket "race" bearings supposedly with the extra oil channel like ACL. Or a combination of both. Good luck man, I always loved your car and your skill at driving, I wish I lived out there so I could get pointers from you
Old Oct 8, 2007 | 06:33 AM
39th_shadow's Avatar
good call. I was going to say lack of oil would have been one of the many things that could have gone wrong. Especially from the look of those bearings damn man... that sucks... But Mrs. Triscuit's explaination sounds like the most logical answer
The rod is snapped right off... these are crazy *** pictures.
