h22 swap in sohc 93 lude please come look im so pissed need help
Old Oct 7, 2007 | 10:13 PM
texastype_r's Avatar
Default h22 swap in sohc 93 lude please come look im so pissed need help
ok i put a h22a (jdm) in the 93 lude that had a sohc in it
the dizzy came with a internal coil
so i took it all apart and put the sohc guts in the h22 housing
now the car back fires and shoots flames out the header and makes a empty doom doom doom noise when i turn it on what all is needed to be changed when doing this swap
it has fuel and it has spark just wont start please help im also using the sohc ecu and harness
Old Oct 7, 2007 | 10:19 PM
Hawkze_2.3's Avatar
Default Re: h22 swap in sohc 93 lude please come look im so pissed need help (texastype_r)
Double check your cam and ignition timing and your plug wires first...
That ECU won't work too well either
Old Oct 7, 2007 | 10:38 PM
well i also tryed a p28 what all is need to make this hoe run i keep reading the dizzy problem what should i do
Old Oct 7, 2007 | 11:08 PM
prelude_93vtec's Avatar
Default Re: (texastype_r)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hawkze_2.3 &raquo;</TD></TR><TR><TD CLASS="quote">Double check your cam and ignition timing and your plug wires first...
That ECU won't work too well either </TD></TR></TABLE>
try gettin your timing right as he said and use some more h22 parts
Old Oct 7, 2007 | 11:46 PM
WHAT H22 PARTS DO I NEED timing is RIGHT!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!
Old Oct 7, 2007 | 11:55 PM
ill worrie about vtec later i just need it to start
ho i have to use a h23 dizzy
Old Oct 8, 2007 | 06:33 AM
championshipwhite93si's Avatar
use the h23 dizzy and EXTERNAL coil.. you need a p13 to have vtec. that p28 will not run the car safe unless its chipped and tuned for the h22. id say your problem lies in the wrong dizzy and the wrong ecu.. if you had a p14 non vtec h23 ecu it would start and run fine, just no vtec..
Old Oct 11, 2007 | 11:27 PM
ok now im useing a brand new h23 dizzy
in the last day this is my quest
2 ecus
3 sets of injectors 1 set was brand new
3 resestor boxs
and a brand new efi
the injectors arnt spraying but i have plenty of
fuel pressure in the rail wtf
moomakudafi
Apr 2, 2005 09:55 PM
whiteb16a
Nov 15, 2004 03:01 PM
KTeller8
May 9, 2003 12:17 PM
MR_F
Feb 6, 2003 01:12 PM
MR_F
Feb 5, 2003 11:19 AM
