need help.. car won't start
Old Oct 7, 2007 | 09:22 PM
r1ch1e's Avatar
Default need help.. car won't start
i don't know if i missed something, but i've check for fire, spark, fuel, compression, timing, and my negatives idk what i'm missing.. can anyone help please!
Old Oct 7, 2007 | 09:34 PM
DCSportEJ1Civic's Avatar
Default Re: need help.. car won't start (r1ch1e)
question is very vague. did the car die while driving? did it act weird before this? did you change something on the car then it wouldnt start? you need to give a little more info. if you have properly checked all this, check it again.
Old Oct 7, 2007 | 09:57 PM
r1ch1e's Avatar
Default Re: need help.. car won't start (DCSportEJ1Civic)
k i drive it over a manhole that was like 3ft high. smashed the oil pan. replaced the oil pan and the pick up funnel. everything was good before i put the oil pan in. went to try and start it didn't start. but when i smashed the oil pan i shut it off right away. then i looked under the car and say oil everywhere . started the car up then drove it to the side of the street. and that's what happened since.
Old Oct 8, 2007 | 06:32 AM
r1ch1e's Avatar
any help?????
Old Oct 8, 2007 | 07:59 AM
slacks's Avatar
what is the car doing when you turn the ignition?
we could help you better if we knew what was at least happening there.
Old Oct 9, 2007 | 07:59 AM
r1ch1e's Avatar
Default Re: need help.. car won't start (slacks)
when i turn the key it cranks over and there is fuel and there's spark. but it won't like run. you know what i mean. like you just keep cranking and the car just won't start. all the elements that's needed to start is there like gas, air, fuel, spark, compression. but it won't start
Old Oct 9, 2007 | 08:02 AM
slacks's Avatar
if it's cranking and getting a spark like you say then it should start
try checking the distributor cap and rotor
as well as all of your connections to and from the cap
Old Oct 9, 2007 | 08:47 AM
ek4_b16a's Avatar
just a funny thought...couldn't happen cause of that, but is your starter bolted in? i know you didn't touch it or anything, but check the connections there too...eheheheh...both my buddies had a start up problem and one was teh starter fell off cause he didn't tighten the bolts...the other one didn't connect one wire to it...ehehehehhe...just a thought...
Old Oct 9, 2007 | 09:01 AM
slacks's Avatar
Default Re: need help.. car won't start (ek4_b16a)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek4_b16a &raquo;</TD></TR><TR><TD CLASS="quote">just a funny thought...couldn't happen cause of that, but is your starter bolted in? i know you didn't touch it or anything, but check the connections there too...eheheheh...both my buddies had a start up problem and one was teh starter fell off cause he didn't tighten the bolts...the other one didn't connect one wire to it...ehehehehhe...just a thought...</TD></TR></TABLE>
good point
make sure everything is bolted in right to lessen the chance of a ground being lost
Old Oct 9, 2007 | 09:43 AM
did you even read the OP. he ran over a pothole and and to replace the oil pan. why would the starter have been off. and hitting a pothole isnt going to knock it loose.
Old Oct 9, 2007 | 08:36 PM
r1ch1e's Avatar
the wires and caps are new. and i've checked all the wires 4 times. and that's all set was going to heck the main relay but had to bring the nephew to the er. so i guess i'll check it tomorrow if it isn't raining.
Old Oct 9, 2007 | 08:44 PM
actek23's Avatar
also check the ignition coil, though you have spark, it may be a weak spark.
Old Oct 9, 2007 | 08:45 PM
mustang5.slow's Avatar
* B A N N E D *
bump
Modified by mustang5.slow at 10:07 PM 10/9/2007
Old Oct 9, 2007 | 08:54 PM
r1ch1e's Avatar
Default Re: need help.. car won't start (mustang5.slow)
oo i was just saying i checked it not with an atititude or anything i appreciate everything bro. the coil is new.
Old Oct 9, 2007 | 09:01 PM
* B A N N E D *
oh shiet i'm sorry r1ch1e i meant to quote DCSportEJ1Civic
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DCSportEJ1Civic &raquo;</TD></TR><TR><TD CLASS="quote">
did you even read the OP. he ran over a pothole and and to replace the oil pan. why would the starter have been off. and hitting a pothole isnt going to knock it loose. </TD></TR></TABLE>
k'mon every body has to throw in theyr two cents. just let people thrw stuff in here.
OP hope everything works out.
Old Oct 9, 2007 | 09:05 PM
r1ch1e's Avatar
its all good bro nothing taken
Old Oct 14, 2007 | 04:54 PM
r1ch1e's Avatar
my up date just did my clutch thinking maybe of the clutch was slipping mayb thats why it wont start. and it wasn't. can't think of anything else.
Old Oct 14, 2007 | 05:34 PM
em1_fox's Avatar
u mite want to check ur distributor
Old Oct 15, 2007 | 04:25 AM
r1ch1e's Avatar
Default Re: need help.. car won't start (em1_fox)
will do today. thanks just thought of it last night when i was searching around.
Old Oct 15, 2007 | 06:41 AM
Probot's Avatar
hmm, is it throwing any CELs?? if it were some kind of sensor issue or electrical it would probably throw code right?
Old Oct 15, 2007 | 07:02 AM
gsxr1k05's Avatar
Default Re: need help.. car won't start (Probot)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by r1ch1e &raquo;</TD></TR><TR><TD CLASS="quote">my up date just did my clutch thinking maybe of the clutch was slipping mayb thats why it wont start. and it wasn't. can't think of anything else.</TD></TR></TABLE>
a clutch slipping wont affect engine starting. you can run the engine without the trans even on the engine. provided your main seal doesnt leak..
Old Oct 20, 2007 | 07:10 AM
r1ch1e's Avatar
Default Re: need help.. car won't start (gsxr1k05)
doing timing. is my new update. been having shietyyyyy weather so today is nice. gonna finish today.
BuddhistPriest87
Honda Civic (2006 - 2015)
Feb 10, 2012 02:40 PM
my_hidden_romance
Aug 19, 2007 10:50 AM
r1ch1e
13
May 13, 2007 05:28 PM
iHOPEyouCHOKE
Jun 9, 2006 02:49 AM
Malice
Jun 18, 2003 07:32 PM
