97 hatch gsr swap. few Q's?
Old Oct 7, 2007 | 09:20 PM
bigislandc2's Avatar
Default 97 hatch gsr swap. few Q's?
Hey guys well this past weekend i just did a swap for a buddy into a 1997 hatchback. So I attempted to search but didnt find anything that helped.
Well so the problem is that when I just rev it alittle past idle the engine rpm would surge up, down rapidly, idle is fine just ailttle low, and when I would drive, it would jerk and drive ok. any ideas on what the problem could be.
For some reason the car doesnt seem to have much power.
let me know if you need anymore info on the car..
there are no codes and a obd1 ecu is used..
Old Oct 7, 2007 | 09:38 PM
DCSportEJ1Civic's Avatar
Default Re: 97 hatch gsr swap. few Q's? (bigislandc2)
sounds like a bad tps maybe. also did you check for codes? theres not always a light when theyre are codes.
Old Oct 7, 2007 | 09:43 PM
Yeah you think a tps. you might be right because when i got the motor the tps was broken off. but didnt seem like the actaul sensor was broken i just re used it though..
Old Oct 7, 2007 | 09:44 PM
Default Re: (bigislandc2)
id hit the junk yard lol.
Old Oct 7, 2007 | 09:51 PM
-JAWSHUA-'s Avatar
i'd try the tps also or the iac, that could also be why your idle is a little low and why it'sa little jerky.
Old Oct 7, 2007 | 09:53 PM
speedooo's Avatar
Default Re: (CTRwannabe)
iac/tps issue. i had the wrong iac on my im causing a surging idle and to lower the surges i adjusted the tps all the way to one side and it made the car really jerky and pedal sensitive
Old Oct 8, 2007 | 11:19 AM
thanks guys for the help. i think it was the IAC, i guess when i swaped over to the round connector one of my sauter came off. the car rips now thanks!!!
89civicstd
Nov 13, 2013 03:56 PM
edd805
Sep 15, 2012 05:19 PM
rTc417
13
Jul 8, 2010 05:05 AM
Alphi
Jan 8, 2005 10:37 PM
